Question about Hunter 28096 Westminster 52" Ceiling Fan with Light
Not working When the fan was initially installed it worked fine. Now it doesn't work on the high setting. It only works on low and medium.
    President:
  • 2,976 Answers
How old is it? If it is more than a couple of years old, the motor windings for highest speed probably failed. They can not be repaired as cheaply as buying a new fan.
Posted on Jan 25, 2009
High and Medium don't work, only low
Check your capacitors to see if they're bad. That's the black box near the pull chain switch with wires going to the switch. If bad call 1-888-830-1326 Hunter parts.
2 wire part # 74132-01-000 ( probably not this one)
Other capacitor part # 74133-05-000 (probably this one)
Jun 02, 2013 | Hunter Dryers
Fan control switch only works on high
If you blower fan will only work on high know that most blower motors are power by a basic electrical circuit that utilizes a multi resistor or a solid-state resistor to control different fan speed modes (low, medium low, medium and high). If the resistor malfunctions it may lose one or more of the lower fan speed settings. First check the fuse and change if needed. If that doesn't fix things change the resister.------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
Our hunter fan won't work on high speed any longer, low and medium speed work fine, when clicked on high - it only goes at medium
Sounds like the variable speed switch may be worn out.
You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies.
Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
Jul 18, 2010 | Hunter Ceiling Fan Control Switch
Hampton Bay Windward II Purchased 2002 The fan has lost high speed. Low speed and medium speed work fine. When the fan is turned on to high speed it runs at medium speed. When switched from high to medium...
Most fans have a small rectangular multi-tap capacitor connected to the speed control in the fan. It is likely that this has gone partially bad. The capacitance values are printed on it. Lighting stores and big box hardware stores generally carry replacements.
Feb 23, 2010 | Dryers
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
No ac / fan only works on high
replace the AC blower motor speed control resistor, it is burned out
Jun 30, 2009 | 1993 Dodge Caravan
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hunter 28096 Westminster 52" Ceiling Fan with Light Logo
100 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
