Question about RCA P46921 46" Rear Projection Television
I hear a sound like a shortcircuit on backside?
Thanks for the answer, yes i have low experience in TV reparation but i dont have the schematics for this TV, if you could send me this to my mail (eduquiros@yahoo.es) or post the link it could be helpfull to solve my problem! And yes i hear a clicking sound. I can power on my TV sometimes and it work regular (clicking sound periodly), but sometimes when i turn on my TV, i hear two or more clicking sound and the TV turn off inmediattly! I am scare because an repair person on my country said that the problem is the ctr´s and want arround $1000 for repair it. I dont thing that the problem are the ctr´s.
Thanks for the help!
  • twbusi Aug 03, 2008
    i turn on the tv and get no picture. it clicks about three times like its going to come on but nothing happens
  • kchapman907 Oct 04, 2008
    I have static sound coming from 1 speaker and no sound coming from the other. How hard is it to change the speakers and is this more than likely the issue?
    Genius:
  • 1,139 Answers
I think the problem is either the power supply/High Voltage board or the IHVT (Integrated High Voltage Transformer). I don't have schematics for this model, in addition you will need to take the IHVT out and perform a ring test on it, also I would advise you to check and see if the Horizontal Output transistor is shorted also, you can do this with an ohmmeter (measure between the collector and ground it should have a high reading if the reading is low the transistor is bad). The ring test can be performed with the use of a Universal Video Analyzer, or a LCR analyzer.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 19, 2008
Mfj manuals
I would recommending sending an e-mail to their tech support. They can best answer your questions. E-mail address is: techinfo@mfjenterprises.com
Aug 24, 2014 | Televison & Video
Philips tv schematic model: 21PT3324/71
Send your email address to me by Fixya and get back a copy of the schematic by return mail.
Jan 08, 2013 | Zenith Z32X31D 32" TV
I have a RCA F25216BC TV that will not turn on..the fuse isn't blown and I need a schematic
Send your email address to me by Fixya, and get a copy of the schematic by return mail.
Sep 22, 2012 | RCA F25216BC 25" TV
Altec mx 5021 schematic diagram
We may not be able to find yet your free schematic diagram,
But if you insist on repairing your computer speaker,
• Open it up , and look for possible causes of
symptoms .
• Check on line for the datasheet of the amplifier,
• Use a multimeter to check for open and short
circuits.
Here is guide when repairing similar Computer Speakers
http://www.fixya.com/support/r4008719-diagnose_not_having_audio_right_channel
Jul 26, 2012 | Altec Lansing Audio Players & Recorders
No schematic F601 blown
Send your email address to me. I'll send a copy of the schematic by return mail.
Apr 29, 2012 | Emerson EWF2004 20" TV
Its a fujitsu siemens I think its 56 inch (its 1 meter 27 centimeter). The tv has a black stripe in the middle,horizontal all over the screen.Its getting bigger.At first it flickered now its egally...
Hello
The backlight bulb at its center has damaged. There will be more than 12 CCFL lamps which comes about the entire length of the screen at the backside of LCD screen to illumiate the screen, ahich in turn adjust its brighness according to the brighness we controls with remote. The center one of your TV is now bad. It can be replaced. You have to open your TV and disassemble the lcd unit to see and replace this lamp. If you are not familier with this work, get it repaired by some experienced service technician. It can be repaired at home. The lamp will have its ratings marked on it. Choose the same rated lamp. OK.
Jul 09, 2011 | Fujitsu Siemens Plasmavision P55XHA30 55...
My mother's tv has horizontal lines when turning it on. Once warned up the lines go away. Can this be repaired?
Can you hear some type of cracking sound from backside of TV when it is turned ON? If yes then these lines are due to leakage of high voltage current from FBT wire that goes into picture tube. This can be repaired. All you need to do is open the TV cabinet and keep it in sunlight (inside facing to sunlight) for sometime so that all moisture is gone. Make sure that TV is not exposed to moisture to further stop this problem. If this is not the case and you don't hear any sound then its some kind of SMPS related problem which can be repaired too. For this you need to contact a qualified technician.
May 13, 2011 | Zenith B27A11Z 27" TV
Norcold N821 Refrigerator. Built after 11APR06. When using A/C voltage I get an error code "A." I had to reset the unit to get the gas portion to function. on the diagnostics menu it says...
Yes there is a schematic but it may not be the best approach to the solution. You may be losing a chip on your board because of what I call bad batch and Quality Control failure.Also the boards owner may not want their board schematic published. Most times when people experience these related problem's you are having they share Q&A in their related group. Daniel here is that group and your answer may be found there. If ths is not the answer you wanted to hear please don't rate. I have found my way around the last 30 years asking those that have been there and done that and it works for me. Click Here=> Norcold N821haywire!
Thanks, Sea Breeze
Apr 11, 2011 | Refrigerators
It looks some one is using my yahoo mail id and sending mails to everyone in my address book without my knowledge. 1. Is my account hacked? 2. Is my password is compromised? 3. Has some one...
1. Yes It is ... I to have similar experience 2. The password is not exactly compromised , but it is a Spyware that tracks your Key strokes and Cache it . Resulting the Hacker may no get the exact password .. but he will able to fool the system.. 3. Probably Yes . 4. I think my above answers gives you much explanation you wanted
Solutions
1. Use Updated Operating System 2. Have a well reputed Internet security suite installed and not the ordinary antivirus . 3. Make Password more stronger by adding numbers , case sensitive letters , and Symbols
Please Rate My answer well and Support me !!!
Nov 23, 2010 | Yahoo Mail
TV will not power on only makes a clicking sound
Sounds like you need a new power supply. if you have component level troubleshooting experience you could open it up and see if you can troubleshoot down to the component in case you cant find the power supply board. DONT DO THIS UNLESS YOU HAVE EXPERIENCE BECAUSE YOU CAN BE SERIOUSLY INJURED OR KILLED BY ELECTRICAL SHOCK... if you dont have the experience take it to a repair shop to be repaired.
thanks,
mc
Oct 28, 2010 | LG Televison & Video
RCA P46921 46" Rear Projection Television Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
