Pioneer BDR205 Bluray Burner Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adobe Encore could not finish burning a DVD DL+R because the hardware failed. Sense code 4444C Contact manufacturer. Is the drive dead?
Anonymous
Level 3:
Master:
  • Master 458 Answers
  • Posted on Jan 27, 2011
Anonymous
Master
Level 3:
Master:
Answers
458
Questions
0
Helped
64143
Points
1395
The harddrive burner is incompartible with DVD DL+R disks. First, attempt to burn the same program into CD R W OR DVD R W after refering to the disk burner compartibility. Also, attempt to ascertain the compartibity of the program. A huge program file usually may begin burning with compartible computers only incappable completing compressing an entire compilation into readable Disk.
2answers
Dual Layer how to burn?
The software that came with the DVD-DL device should be able to burn 8GB to dual-layer media.
If not, access http://www.MajorGeeks.com and download the _free_ "Ashampoo Burning 6" software.
Install it, and use it to create & burn onto dual-layer media.
My gsa-t20n will burn regular disks but will not burn DL disks all of a sudden...it burns most of the way then Nero says it cannot finalize disk. 22:48:29] NeroVision [22:48:29] NeroVision 10:36:44 PM ...
Hello there jpd0490.
Here's your geek-steer ...
There are principally two chief causes for this type (calibration) of burn failure:
  1. Inadequate quality media (disks). Verbatim is always a solid choice. However, more important than the brand-name disks are sold under, is the actual manufacturer. You can determine this with the aid of a little software tool called "DVD Identifier". There is an entire sub-culture devoted to tracking the best media available, right down to the manufacturing lot level.
  2. Drive failing. Since you say that it works consistently otherwise, this option is unlikely.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
When previewing my video in adobe encore, it looks fine but when i burn to dvd, the video jumps everytime the camera moves. What can i do?
This is everything from adobe encores website.
Playback issues in Adobe Encore DVD 2.0 have a variety of symptoms. The following symptoms may occur when you use the preview feature, when you play video in the Monitor panel, when you play to an external device, or when you edit a menu or slide:
-- Video or audio exhibits stuttered playback.
-- Video or audio cut in and out.
-- Audio is out of sync with video.
-- Video displays as black in the monitor panel or after burned to disc.
-- There are general redraw problems in the user interface.
-- Encore DVD returns the error message, "Invalid requested time," when you transcode a file.
Beginning troubleshooting
1. Test the DVD on a variety of players.
Not all DVD players behave the same way. By testing the DVD on a variety of players, both set-top and software, you can determine if the problem is related to the DVD itself or just the player.
2. Make sure that the system meets the requirements for digital video.
Video may not play correctly if your system doesn't meet the following requirements:
-- Intel Pentium 4, 1.4 GHz processor or faster
-- Windows XP Professional or Home Edition with Service Pack 2
-- 512 MB RAM (1 GB or more recommended)
-- Hard disk with at least 16 GB of space for installation and ongoing work (RAID recommended for HDV/HD editing)
-- 1280 x 1024 or greater color monitor resolution, 32-bit display adapter
-- QuickTime 6.5 required to support import and export of QuickTime files
-- Supported DVD burner *
-- Stereo sound card
* For a list of supported DVD burners, visit the Adobe website at www.adobe.com/products/encore/systemreqs.html.
3. Update video display card drivers.
Outdated or flawed video display card drivers may incorrectly display motion video and textures, or incorrectly report their ability to display motion video or textures to Adobe Encore DVD. Contact the video display card manufacturer for the latest display drivers and driver information.
4. Select an appropriate Playback Quality setting.
You can display playback in the Encore DVD Monitor panel at either High quality, Draft quality, or Automatic quality. By default, the Monitor panel displays video at High quality; that is, it displays all the pixels of each frame of video. When Encore DVD plays back unrendered video at High quality, the video may stutter or ****. When you select Draft quality, Encore DVD always displays video at one-half resolution in the Monitor panel. When Draft quality is selected, playback is smooth but the image quality is affected. When you select Automatic quality for the Monitor panel, Encore DVD dynamically adjusts image resolution between High quality and Draft quality to best address the available system resources.
To choose the Monitor panel playback quality, select File > Preferences > General, and then select an appropriate Playback Quality setting.
5. Deselect the Automatic option in Audio/Video preferences.
1. Choose File > Preferences > Audio/Video Out.
2. Under Video Playback, deselect Automatic.
3. In order for the change in preference to take effect, you must close the Monitor panel and then reopen it.
The Automatic option is selected by default, allowing Encore DVD 2.0 to play video in a Standard Direct3D mode. When it is not selected, video plays in GDI mode.
6. Troubleshoot slideshow playback issues.
Many DVD players, both set-top and software, handle playback of slideshows differently. To conserve disc space, Encore DVD creates an MPEG I frame for each slide then assigns a duration for that frame based on the slide's duration. Many players cannot accurately display these and will instead display only a single frame of the image before reverting to a black screen for the duration of the slide.
If you are experiencing playback issues with your slideshow, be sure to play it back using a variety of players. If you determined that slideshow playback is the issue, then you can try the following workarounds to ensure the slideshow will playback correctly on all players:
Note: The following workarounds will increase the amount of space used on the DVD.
Add zooms or pans to each slide.
When you add a zoom or pan effect to a slide, Encore DVD will render the slide as a video file instead of an MPEG I frame with duration.
Create the slideshow in Premiere Pro.
You can import all of your slides into Premiere Pro and create a slideshow there, then export the file as an AVI, import it into your Encore DVD project, and add it to a timeline.
If you create the slideshow in Premiere Pro, users cannot manually advance through the slideshow the same way they can if it was created with the Encore DVD slideshow editor. However, if you add chapter points for each image, then viewers can skip ahead before the timeline automatically reaches the next image.
Create menus from each slide and link them.
By creating menus from each slide and linking them in the desired sequence, users will have complete control over when they can advance to the next image. You can set up invisible buttons with invisible highlights to give the impression that only the image is on screen, or you can include visible navigation elements for the next and previous slide, as well as any option that is available for a traditional menu.
If you create menus for each slide and link them, then you cannot have a continuous soundtrack playing throughout the slideshow. Menus can have audio but they are specific to each menu and will start from the beginning each time you access a new menu.
Intermediate troubleshooting
7. Optimize hard disks.
Optimize hard disks by defragmenting them, updating their drivers, and configuring the disk drives. These procedures improve playback speed and performance in Encore DVD. For further assistance with these tasks, contact the hardware manufacturer or an authorized repair service facility.
-- Defragment hard disks by running the Disk Defragmenter utility included with Windows or a third-party disk utility such as Symantec Norton Utilities. If you use external (non-system) disks for video, you can reformat them instead. Be aware that formatting erases all information on the disk. For instructions, see Windows Help or the documentation for the utility.
-- Update disk drivers to ensure that they aren't damaged or incompatible with the system. If a disk was formatted with a third-party disk utility, you must use the third-party disk utility for this procedure. For instructions, see the documentation that came with the utility.
8. Test digital video playback in a third-party digital video utility.
Play your video clips in an application other than Encore DVD to try to isolate the problem. If playback is problematic in an application other than Encore DVD, the problem is not with Encore DVD; troubleshoot your system or that video file.
9. Optimize Encore DVD.
For information about optimizing Encore DVD, see the Encore DVD User Guide, Online Help, and document, "Optimize performance of Encore DVD (on Windows XP)."
Error burning to Dual Layer DVD
Do you have a dual layer burner, you need one to burn dual layer dvds that may be your problem hope it helps
What BRANDS are compatable w/ HL-DT-ST DVD+-RW GSA-T21N? I have no problem burning regular DVD or CDs but can't get a complete burn (second layer) on DL. I'm currently using (failing) MEMOREX DVD+R DL. ...
My friend as the same burner on is dell laptop and he just burned 2 xbox 360 games on TDK DVD+R DL disks and it worked good but it took about 3 mins to finalize the disk so let your program finish
LG 18x SuperMilti DVD Burner DVD=/-RW/DL/Ram Oem
Depends what software you are using to burn. Use Nero. then select dvd or cd or whatever. You must state what you are burning onto - you cant create a cd then put a blank dvd into the drive - common sense
2answers
NEC 3540A stopped reading blank DVD+DL
Hi JonPM
Burning a dual layer disk requires a functionality of the drive that is not used in the burning of normal disks. But before we consider that the drive may have a mechanical problem, lets clean out all your temporary garbage. Click on this link and download Cleanup 4.5.2 (http://majorgeeks.com/CleanUp_d4895.html
Instal and run the program. Once it has finished, reboot your computer and give burning onto the DL disk another try. Let me know what happens.
-C
2answers
Problem burning DVDs
This happened to me also. I fixed the problem by buying new DVD discs, sometimes the mac's rom doesnt like particular discs. Its a trial and error thing with which ones it will use. Make sure you are using the latest version of Roxio toast to burn with, also make sure your ROM is DVD-R.
If all this fails, it could be your writer in the rom. Try burning a CD, if that works it will be the above problems.
Try using discs with a GOLD BOTTOM, it seemed to work for me.
Top Pioneer Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
