Lanier LD 325 Printing labels
I have a Lanier LD 325 printer and I want to print labels on a sheet that is 4"x6" and not the standard 81/2"x11. Can you tell me how I do that?
Thank you very much.
Diane
  • Anonymous Mar 18, 2014
    sc546
  • 2,794 Answers
4 x 6 might be too short for that copier to run on. The bypass tray might take it if you load it so that the 6" side is the longest end that the copier is feeding throught the machine.
If you have it interfaced as a printer, goto avery.com and download their label making software and find the template that matches your label stock. The software works with Microsoft Office files as well.
Posted on Jul 19, 2008
How can I get A Lanier LD-620C parts manual
The LD-620 appears to be a Ricoh Aficio MP-C2051 or C2551.
You should be able to find a parts list on the net. Whichever one looks the same as your lanier (who don't make anything) will be the one.
Good luck
Oct 03, 2014 | Lanier Office Equipment & Supplies
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Sep 11, 2014 | Lanier Ld 430c With Feed, Bank, Print,...
Lanier ld 435 color print code sc548
re install fixing unit and do the sc reset. press clear mode 2x 107 press clear/stop until COPY SP appears press Copy Sp then exit, turn off machine then on after 5 to 10 seconds
Aug 23, 2010 | Lanier Office Equipment & Supplies
Tray 1 is not set correctly, yet everything is set right. Help
81/2 x 11 is not a custom paper size. Set tray 1 to 81/2 x11 plain paper and set your print driver the same way. the descriptions have to match or it will not print.
Jan 05, 2010 | Lanier UNKNOWN
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
I have a Lanier LD 232c. Every print job we try to send through is resulting in a paper jam. What should I look at?
Make sure that all the paper trays have the correct size and direction (portrait or landscape) in both the copier and print driver.
Jul 06, 2009 | Lanier Office Equipment & Supplies
162 people viewed this question
jasbo
jasbo
