Question about Brother LS-2125 Mechanical Sewing Machine
I cant tread my ls2125i sewing machine - Brother LS-2125 Mechanical Sewing Machine
  • hebasin Jul 19, 2008
    can't thread the bobbin either. help!
    h
All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Posted on Jul 23, 2008
How to adjust driver timing on brother ls2125i
What exactly is a "driver?" That is not a part normally associated with a sewing machine.
Nov 22, 2016 | Brother LS2125i Sewing Machine
The driver on my brother ls2125i won't move when trying to sew
If you are referring to fabric not feeding through...make sure the feed dogs were not accidentally lowered. There should be a switch/lever to raise and lower feed dogs. May have to remove extension tray/table to have access to switch. NOTE: even if switch is moved, the hand wheel will have to be rotated at least 1/4 a turn before results from switch selection becomes "active".
My Sewing machine isn't catching thread at the lower bobbin.
check the needle /hook timing as this the indication that it is out
May 18, 2015 | Brother LS2125i Sewing Machine
Unlock brothers LS2125i sewing machine
Is the thread caught in gear in top of machine causing it to bind. If you refilled bobbin did the gear switch back completely or you have lost an o ring in bobbin rewind.
Oct 16, 2014 | Brother LS-2125 Mechanical Sewing Machine
Just purchased my very first sewing machine and I'm having a problem threading it my manual was not included for some odd reason is there any way you could help me. Some instructions or manual on how to...
It was quite difficult to locate but I found the manual for this system for you. Please make sure to rate my answer 4 thumbs up, it would mean a great deal to me. I would be forever grateful if you could do so. Here is your manual, which I have hosted on my personal webserver:
http://micromatikal.dlinkddns.com:8000/cust/LS2125i.PDF
Oct 12, 2010 | Brother LS2125i Sewing Machine
Bobbem is not right,tread knotting,cant sew
Adjust the bobbin screw tread tension, its too tight.
May 24, 2009 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
63 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
