Question about Cuisinart Thermal DGB-600 Grinder
Grinder hard (impossible) to remove
Fairly new DGB-600 or DGB-500. Worked well for first couple of months. But now, regularly, the grinder is impossible to remove. The only one who can pull is out after we make a pot of coffee is my 6'4'' husband.
I make sure it is completely clean and dry before inserting it. I even have cleaned the entire seating area with cuetips, but no matter how pristine the set up is, once the coffee is brewed, the grinder is impossible to remove.
Is this a standard problem? Would a replacement grinder do the trick?
  • 3 more comments
  • Blue Essence Oct 05, 2008
    I have the same problem. Impossible to remove please help.
    Blue Essence
  • westendarp Dec 30, 2008
    Ditto. Somebody please find a fix.
  • jaymej Jan 25, 2009
    I have NEVER been able to remove the bean basket. How can i do so? ('cause I can't get grease under it unless I can remove it!)
  • javanut Feb 06, 2009
    mine has been difficult to remove and now it is really stuck so I can't grease it up until I get it out somehow how. I'm ready to take a hammer to it!!
  • anitarae Feb 06, 2009
    Lubricating both the male and female parts does help. It is important to make sure the grinder is well seated, so junk can't get under it. Greasing and firmly seating the grinder ends up helping about 80% of the time, but there are still times when only a strong arm will get the grinder out. I wonder if Cuisinart has solved this problem with newer models?
I took the top off the entire machine (it snaps on and off) and took a butter knife to get under the grinder from the back. Using a little leverage, it popped off. I put Vaseline petroleum jelly on the male and female parts before my next use and it STILL got stuck. So I turned the machine around to the back, took off the lid, and used the knife again. Oh well, at least I can get it out….
Posted on Feb 06, 2009
I had the same problem and used a little grease and it worked fine. Take out the bean cup and grease the male and female parts and it should work fine.
Posted on Oct 06, 2008
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Coffee pot
As long ago as you posted this, the unit has a 3-year warranty - call Cuisinart and redeem it.
Jul 24, 2008 | Cuisinart Thermal DGB-600 Grinder
Grinder basket removal
Vinegar instead of WD40 - I am pretty sure a good portion of the DGB-600's have this problem, but that is hearsay.
May 31, 2008 | Cuisinart Thermal DGB-600 Grinder
1) Rinse area with vinegar/water on a cloth to break up oils
2) Fill grind chamber with ice covered in a small plastic bag - try removing again after 10 mins
Fairly common with the DGB600's IMO
-Tha Mp3 Doctor
Apr 28, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
Nov 19, 2007 | Cuisinart Thermal DGB-600 Grinder
DGB 600 Grind & Brew
Had the same problem, I used coffee pot cleaning solution a couple times through and it woks fine. Had to do this a few times now. Cleaning solution is the type bought at local retail store.
Aug 03, 2007 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Thermal DGB-600 Grinder Logo
253 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
