Question about Indesit Washing Machines
Using a washerdryer
Taking a long time to dry clothes 3hrs and still wet
  • 57 Answers
Hi what I would advise you to do is check to see if the blower is working take the top off the machine and switch on the dryer and listen for the motor working if it is then switch it back off and feel the heater housing to see if it is warm if not the reset on the stat may need to be press if this is still not the fault check fan on the heater motor could be broken and the motor is just spining
Posted on Jul 18, 2008
How to Make a Non Working Xbox Disk Work?
    1)Take disk out of Xbox
    2)Try turning off Xbox
    3)Choose one of the methods to try and fix disk Polishing disk
      -Use air first (blow across disk, or use a soft brush to remove any specks from disk before polishing)
      -Get a soft, lint-free polishing cloth (make it damp)
      -Use wet side of cloth to clean shiny side of disk
      -Dry whole disk (dry polishing cloth)
      -Put it in Xbox Using soap or water
        -Use soap or windex-slightly wet paper towel to wipe off disk from middle towards outside
        -Use furniture cleaner Using toothpaste
          -Rub toothpaste on disk, dampen a suitable soft cleaning cloth
          -Rub from centre-then move all the way around to edge
          -Wipe toothpaste off with a wet cloth-wipe any dampness with dry cloth
          -Put it in Xbox Using car polish
            -Get a dry cloth and add a small amount of polish to it
            -Rub in a circle motion, then wipe dry
            -Put it in Xbox Peanut butter
              -Put a dab of peanut butter on a lint-free cloth
              -Don't rub it in a circle motion
              -Put it in Xbox Using rubbing Alcohol
                -Pour out a small amount of rubbing alcohol onto a cotton bud
                -Rub from centre of disk, moving outward to edge
                -Wait for it to dry and try again Wax from candle
                  -Get some melted wax from a normal candle
                  -Gently pour wax on scratches-rub in with soft cloth
                  -Wipe off excess wax with a damp cloth
                  -Let disk dry for 5-10 mins and try again Vanish Oxipowder
                    -Cover entire shiny side of disk with powder
                    -Wait 5-10 mins
                    -Clean powder off completely with soft damp cloth
                    -Place disk in Xbox Other possible fixes
                      -Take disk to game/computer shop
                      -If any of your friends has game, borrow disk from them, install it to hard drive, and hope Xbox recognises it
Oct 20, 2016 | Video Game Consoles & Games
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
Does not dry cloths. dryer gets hot,top and sides during drying cycle. it takes 2-3hrs to get cloths dry.
most probable cause of heating yet not drying in a crushed or restricted vent (imagine only inhaling while breathing yet not never exhaling)
Jul 22, 2011 | Kenmore Washing Machines
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
It take 3hrs to dry clothes
Check and clean the lint filter and all the duct work on the dryer and the external duct vent for lint buildup.
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
Feb 11, 2009 | Whirlpool LEQ8611L Electric Dryer
Proline tdc6a taking 3 hours dry clothes
is it getting hot ? if not then its either the heating elements or thermostat. both available on espares. Most likely to be thermostats. If its heating then give the condensor a good clean. hope this helps.
Oct 29, 2008 | Dryers
Washing Machines Logo
42 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
