Question about Video Game Consoles & Games
I get red rings when i turn on my xbox 360 - Video Game Consoles & Games
    Problem Solver:
  • 8 Answers
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Posted on Jul 18, 2008
  • 34 Answers
SOURCE: 360 Xbox problem Three red rings
Unfortunately there is nothing that you can directly do to fix this problem.
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
http://support.microsoft.com/kb/907534
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
Posted on Nov 16, 2007
  • 25 Answers
SOURCE: xbox 360
that means that it is realy broken you have to contact the company expersts in order to fix it or return it for a new one it might cost you a little but thats the only way i think possible
Posted on Mar 29, 2008
  • 44 Answers
SOURCE: my xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Posted on May 14, 2008
SOURCE: Xbox 360 wont load to main menu. No red ring.
If there is one red light it might be your harddrive. Make sure its fully plugged in.
Posted on Feb 26, 2009
time_addict
SOURCE: how to fix the 3 red rings of death on the xbox 360
I tried to follow some video tutorials from youtube but none of them worked. So I realised I'd have to spend some money on real tutorials and tools. I was a little sceptical but I bought it any way and it worked just fine.
Eventually you'll have to spend some money on it. I recommend you get your hands on this set, you'll get your guides and tolls and it's all you need to fix it at home.
http://74f064-ykk5jh88anp4wf45wch.hop.clickbank.net/
Posted on Oct 11, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
When i turn on my xbox I get a the "red ring of
order the red ring of death self repair kit,,very simple,,also try blowing xbox out with a aircompresser,,worked for mine,,and geta hex head screww driver tighten screws on the botom of xbox 360,,,may hlp...
Nov 03, 2010 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
I turn on my xbox 360 and it says go to
how many lights is it? 2 lights- http://support.microsoft.com/kb/907533?sd=xbox 3 lights- http://support.microsoft.com/kb/907534?sd=xbox 4 lights- http://support.microsoft.com/kb/906652?sd=xbox
Hope this helps!!
Jun 28, 2010 | Microsoft Xbox 360 Console
Xbox 360 power supply light turns yellow when xbox 360 is off (usually i think) and turns green when on, I've had one red ring on my xbox to,twice
make sure your xbox is in an open area where it can breathe, otherwise the one red ring means there is a hardware failure, if it is under warrenty send it back into xbox, otherwise there are some diy fixes on youtube
Mar 02, 2010 | Microsoft Xbox 360 Console
First the red ring and now my xbox 360 wont turn on!?!
well you screwed thats what red ring does just try un plugging it and keeping it in some towels
Mar 28, 2009 | Microsoft Xbox 360 Console
Red ring
You have the''Red Ring of Death''.When I had it I turned off and on the 360.It worked for me.If it dosen't work for you send it to Microsoft so they can fix it.Hope I could help.
Jan 28, 2009 | Microsoft Xbox 360 Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Red ring
check your AV cables
Jan 23, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
152 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
