I am trying to fix a door handle that will not open from outside
Turn the window handle to where you can see a small 1/2" slot rt at its base where it meets the panel.you'll notice a small brass v shaped clip,you'll need hooked pick or something simular to hook this clip and pull it out of its slot,this release's window crank handle. Once this is off the rest of panel is held on by plastic panel clips that pull loose by pulling panel outwards from door ,and also by a few various screws. once panel is off temp. slide window crank back on and crank window all the way up. You then should have clear view of outer door handle. Handle has two rods attached to it,one for lock assy., one for latch release.This is the one you'll be looking at.Most likely you will find rod has came loose due to broken retainer clip at handle,or casting on handle itself has broken off.If clip is broke you can buy new clip at dealer or at some autoparts outlets,replace and reattach rod(make sure rod locks into place).If handle casting is broke will need handle replaced.It is held in place by two 10mm bolts,two rods preeviously mentioned. If handle is body color matched will need color code(on door jam sticker)to order handle from dealer to match.Lock assy will need to be transfered to new handle,it is held in by two spring clips.You notice two holes one on each side of lock,you will need to push release clips inwards through each hole to release lock and slide it out.to install just push down into newhandlle until clips engage. Let me know if you run into problems. Good luck and if this was able to help you please leave me some positive feedback. Thanks and good luck, Joel
