Question about JVC AV-32260 32" TV
V-chip how can I find my set code to reset my v-chip? jvc 20 in Model number AV-20FD24
  • 385 Answers
You can find some information about the V-Chip here at this link on page 19,20 & 21.
It doesn't tell you exactly how to reset but it may be of help to you in whatever you need to know.
Thanks,
Lolita
Posted on Jul 18, 2008
Reset jvc model AV-32020
To reset it to factory settings, you have to enter its service mode option. If you wish to get more details about how to enter, adjust and exit service mode, check this site. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 12, 2013 | JVC AV-27430 27" TV
Whats the part number for convergence chips on jvc av-48wp74
There are two of them that need to be replced as a set. They are both STK392-110 Convergence Ics you can get the original oem Ics from www.tvrepairworld.com they are listed under the Integrated Circuit catagory you only need the one set. They also have the convergence repair kit listed for your model under the JVC repair kits the kit has both ICs all 12 resistors and the CD with step by step repair instructions.
Oct 17, 2012 | JVC AV-48WP74 48" Rear Projection...
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
Vchip reset? Inputs won't show HDMI input option. Floor model TV model# av-48P786 sn#13090154
Hello
If a power interruption occured to your household power supply, V-Chip has to be resetted. To reset the V-Chip do the following.
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
preset with a lock code of "0000". You may change the code to any four-digit number you wish.
To change the lock code, follow the steps below.
Press the MENU button
To SET LOCK CODE use UP/DOWN buttons.
To operate (lock icon appeares on pressing =>/ Press ZERO to access the lock code
The first digit will be highlighted
Use =>/<= button to
To select the number
Press Up/Down button to
To move to the next digit
Continue to follow these directions for all four numbers
Press the OK button to finish (your lock code is now set)
Press the Menu button when finished
OK. Thanks for using Fixya.
Apr 07, 2011 | JVC Televison & Video
Hi lt40fh jvc how do i get the channel locks off please
Hello
If you forget the Lock Code, a new code may be set using the steps listed below.
After a power interruption you must reset the Lock Code
Channel Guard and V-Chip settings are protected by a four-digit Lock Code. Your TV comes pre-set
with a Lock Code of "0000". You may change the code to any four-digit number you wish. To
change the Lock Code, follow these steps
Press "UP" or "DOWN" button RESET LOCK CODE
Press RIGHT or LEFT button to operate
The Lcck Icon appears.
Press ZERO to access the Lock Code
Press RIGHT or LEFT button to seelct the number.
Press UP or DOWN BUTTON to move to the next digit
Press UP or DOWN button To FINISH
Press RIGHT or LEFT button to save settings and exit
Your new Lock Code is now set.
OK.
Dec 28, 2010 | JVC AV-27230 27" TV
Dear SIR Please send me the number part of Convergence Module for JVC Model AV-48WP74. THANKS FOR YOUR ASSISTANCE
I WOULD DOUBT THE BOARD IS AVAILABLE and you if you have convergence problems can have it repaired for 1/10th of what it would cost.
Only Two IC's and or one or more resistors fail on this board.
It is easy to actually get the board out of the set.
See attached photos of the board:
It uses two of the STK-392-110 chips ( A pair can be purchased on EBAY for about 12 dollars!) If one or more of the resistors are bad they are easy to locate and replace---generic part and each part on this board has a location number printed next to it.
Less than 20 dollars in parts, about 40 minutes to remove board, replace parts and put back--all you will need if it works is the JVC remote to use to adjust convergence.
If this told you something (or the photos helped you) rate this solution as, very helpful as I do this here for free.
Regards, SD TECH
view of board from back removed from set
view of board removed from set from front
view of back side of board--two stk-392-110 chips and in front of them the protection resistors
Aug 13, 2010 | JVC AV-48WP74 48" Rear Projection...
Program my tv combo with my rca universal control
Try following codes for JVC tv/video combo.
012 - 024 - 036 - 037 - 040 - 048 - 051 - 074 - 002 - 014 - 016 - 030 and 046
Hope any of them will work for you.
Thanks.
May 18, 2010 | JVC AV-20FD24 20 in. TV/DVD Combo
I have cable hook up through a normal cable and I can only get two channels how do you program the channels in on a jvc av 20fd24
You should be able to go into the menu settings and select channel, then Antenna, then the type of source your have, Air, or cable...select one then press enter, or ok...should do everything for you.
Oct 19, 2009 | JVC AV-32D305 32" TV
JVC AV-20FD24 will not pick up the signal from the antenna. I Moved tv from my daughters apt to my home and now it will pick up only 67 , 69, 27, 57, & 25. I am currenty using an antenna on top of...
On the JVC remote there should be a setup button. Sometimes they call this Main. Regardless, once in setup you'll need to change the input from cable to antenna. This should solve your problem.
Oct 12, 2009 | JVC AV-32D305 32" TV
JVC model av-20fd24
default, return product, or is the dvd a burnt or ruind or out of region disc. many problems occur with this.
Jul 13, 2008 | JVC AV-20FD24 20 in. TV/DVD Combo
JVC AV-32260 32" TV Logo
94 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
