Go here and run through the trouble shooting list and see if you can fix your problem.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/disc-drive.aspx
SOURCE: xbox 360 doesn't read any discs
Don't know if I'm telling you something you already know buddy , but the Xbox360 user manual specifically says "Do NOT use a CD laser cleaning disk" I had a problem with my 360 see post "disk read errors" (still unsolved) I ended up buying a new 360 but then took my old one apart and tryed cleaning lenz with cotton bud and tricloroethane - to no avail
SOURCE: Xbox 360 wont read disc
Though i fixed the Disc Read Error myself within
an hour but please test the below method at your OWN Risk. Please
also note that microsoft is no longer providing Extended warranty for
E74Error.
Check out this DIY Video Guide,that
explains step by step instructions to fix Disc Read Error
yourself within an hour. It also provides the money back guarantee in
case you are not satisfied. As i fixed my Xbox myself so i thought to
share it with you guys.
SOURCE: My XBOX 360 elite is not reading discs.
sounds like your Disc Drive has taken a **** I have had the same issue and I had to open it up to make the drive start to spin again
SOURCE: xbox 360 does not read discs
Try using a disc cleaning unit on this if that does not work the drive will need to be replaced around $75 bucks these people at www.videogamerepair.com will do the work for you if you do not know how.\
Thanks I hope this information was Very Helpful
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: put disc in xbox 360, said reading then open tray.
When the disc tray closes push down firmly on the top of your xbox where
the tray is. if not clean your disc.
This is normal when the lens are dirty since the sensors are very sensitive.
Good luck.
Testimonial: "hi yes lens was dirty,thanks"
This is a problem occurring in all the xbox 360 consoles.......
this is mainly because of the poor quality of the disc.....as a result it leads
to the damage of ur xbox 360 lens..............use good original
discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better
download this Repair Guide for further information .........
CLICK HERE to download
