Question about Ovens
Creda Double Gas Oven. Model Europa Gas.48132.Serial No: 83 1 00087
When top oven is set to Mark 8 it does not reach that temperature.Gas flame appears to be greatly reduced.
Would appreciate obtaining a maintenance manual, I am capable of carrying out any repairs on this type of equipment.
  • parse Jul 18, 2008
    Thanks VOLTA Model No; 48132. Where is Circuit Board Located
  • parse Jul 19, 2008
    Many thanks Junoon 007. Sounds logical will check it and comment
    Genius:
  • 1,011 Answers
Dear Sir/madam,
This is what should happen:
1. You have a call for heat at the thermostat and the purge fan turns on.
2. 30 to 60 seconds later, you will hear a clicking sound or a glow plug ignitor get bright.
3. The pilot should light and withing a few seconds, the main burner should ignite.
4. The main burner will stay lit without the fan turning on. The fan should turn on automatically about 45 seconds to 2 minutes, depending on the temperature sensor in the heat exchanger.
sorry i cannot found maintenance manual in internet.
Thanks
Good luck
"Don't forget to rate the solution"
Posted on Jul 18, 2008
  • Ovens Master
  • 6,487 Answers
The circuit board is what is likely causing your problem why the its doesn't reach the needed temperature. By the way what is the model number of your unit??
Hope that helps.........
    Scholar:
  • 101 Answers
I would contact the manufacturer and ask for the repair manual, it does not appear to be available online. Here is a link for the contact form. Hope this helps.
  • Jerrod J
    Jerrod J Jul 18, 2008
    This might be a more suitable contact form, depending on your model.
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Dec 05, 2010 | Creda Europa E010E Electric Single Oven
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
Creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Apr 06, 2010 | Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Broken hinge on Europa oven
try Ausralian Bakery and Pizza, Equipment Importers
122 Whitehorse Road, Blackburn, Victoria, Australia. 3130
Telephone: +61 3 9878 6900
Facsimile: +61 3 9878 6966
They import Europa equipment
Dec 04, 2008 | Creda Europa E010E Electric Single Oven
Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Aug 28, 2008 | Ovens
Ovens Logo
263 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
