Washing Machines Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is not spinning now. - Washing Machines
  • Bruce Denton Jan 27, 2011
    I need to know what brand and is it top load or front load
Anonymous
Level 3:
  • Washing Mach... Master 43,501 Answers
  • Posted on Jan 27, 2011
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10834996
Points
101584
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Anonymous
Level 3:
President:
  • Master 1,654 Answers
Anonymous
Master
Level 3:
President:
Answers
1654
Questions
0
Helped
597671
Points
5047
Depending on the make and model top loader or front loader, the most common issues are the lid switch or door lock safety interlock, or the pump filter is clogged and need cleaned. Let me know what machine you have and I can go from there.
1helpful
2answers
Which Shimano spinning reels are best for catching catfish?
  • #1: Daiwa BG Spinning Catfish Reel.
  • #2: Shimano Stradic FL Spinning Catfish Reel.
  • #3: Penn Spinfisher VI Spinning Catfish Reel.
  • #4: Shimano Sedona FI Spinning Catfish Reel.
  • #5: Okuma Avenger Spinning Catfish Reel.
5 Best Spinning Reels for Catfishing - Buyers Guide - Slo-fishing
and more
https://www.google.com/search?q=Shimano+spinning+reels+are+best+for+catching+catfish
Dec 23, 2021 • Fishing
1helpful
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 • GE Dryers
1helpful
I am looking for wa10r3 samsung washing mahine washing but wont spin,sounds as if is spinning but wont spin.please help me
check underneath for a solenoid that engages a lever or clutch to connect the belt drive to the base of the tub
it it is not slapping in when it goes to spin , it will not spin
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
Will not spin on spin cycle
Brian...You have a Non-compliant washer! Brian...You need to replace and Install a New Drain Pump! She will Spin, Spin, Spin all day long afterwards~
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
2helpful
Not spinning on spin cycle
No spin is electrical!
Hi, I have SW1ASP Samsung 6 kg washing machine. Its washing but not spinning. its try to spin and motor try to pushing to spin but it spin slight and stop. When i jiggle the machine while it try to spin...
1) may be your spinning cloth load over.
2) Check inside the container (space of wall & spin tube) cloth may be inside.
3) Door stopper (Brake) position not correct.
Actually the spin motor starting slowly first.
2helpful
2answers
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Top Washing Machines Experts
john h
