Question about Kenmore 15864/15862 Top Load Washer
80 series kenmore washer
Trying to find a diagram of the inside of the gearcase for a Kenmore 80 series clothes washer. Mainly how the 3 peices set on top of the gear and pinion.
  • 2 more comments
  • csnoop Jul 18, 2008
    Needing a diagram for the inside of the gearcase for an 80 series Kenmore washing machine. Mainly the how the 3 parts set on top of the gear and pinion assembly.
  • steve galvan Jan 22, 2009
    I have the same problem, took transmission apart before checking coupler between motor and gear box. problem was no spin cycle, found the coupler for $15.00. Need a parts blow up or repair manual to correctly install the three parts on top of drive gear.
  • Anonymous Feb 27, 2009
    PUTTING TOGHTER
  • dustinw Apr 25, 2009
    I also took appart my gear box on my 80 series kenmore before checking the motor coupling and want to make sure that i have it all back together right. Where can i find a diagram of the gear box?
  • 91 Answers
If you need part number is 110---3360629 gearcase fo all direct drive transmission
Posted on Jan 04, 2009
  • 39 Answers
Try this:
http://beta.searspartsdirect.com/partsdirect/partsdirect/getSubComp.pd?diagramPageId=00004&documentId=P0012168&modelNumber=11010202001&productCategoryId=0153200&brandId=0582&modelName=&blt=06
Posted on Jul 09, 2010
4 Suggested Answers
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
  • 58 Answers
SOURCE: kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Posted on Jul 01, 2009
JULIANFIX
  • 975 Answers
SOURCE: How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Posted on Oct 26, 2009
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Mar 26, 2010 | Kenmore Washing Machines
Kenmore washer agitates on spin cycle
Obviously the washer should be either just spinning or agitating. The transmission ,or in this style washer it is called the gearcase, is bad and would need to be replaced. The gearcase controls the spin and the agitate in this washer. The part number is 3360629 and retails for $172.77. To replace; Unplug washer, remove the 2 trim pieces on either side of the console, remove the 2 screws under the trim, lift the console and rotate to the back, remove the 2 retainers going from the back into the cabinet, remove the cabinet, remove the drain pump, remove the motor, remove the agitator, remove the gearcase with 3 bolts holding it on. The gearcase will now slide out of the washer. Transfer the clutch and motor mounting plate to the new gearcase and reassemble in the reverse order.
Thank you
Jan 23, 2010 | Washing Machines
Kenmore 80 series, model 110-2781690, won't spin or agitate. loud clicking from lower portion of machine. fills & drains ok. transmission failure?
hi,
Unfortunately, it sounds like a transmission/gearcase problem, mainly because you stated the motor would run, but would not agitate or spin.
With the motor removed from the gearcase, try to turn the coupler on the gearcase side one way for many turns, and see if your agitator moves back and forth, then turn the coupler on the gearcase the other way many turns to see if the tub starts to move
thank you,
vijay
Sep 29, 2009 | Kenmore Washing Machines
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will not spin or agitate
This is a bad coupling, part # 285753. It is available from timerking.com for $9.99, and other places as well. To replace unplug and lay the machine down on its back, remove the 2 pump clips, and slide the pump out of the way. Then remove the 2 motor clips and remove the motor. The coupling is between the motor and gearcase. Hope this helps!
Jan 13, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator does not spin.
The clutch needs replacing. The gearcase needs to be removed and the centrifugal clutch is mounted on the gearcase.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
1,789 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
