Question about HP NX9010 Notebook
Keyboard problem! when i power up HPnx9010,the "K" alphabet press by itself,causing problems.I cant type again with it ,cause an attempt to type automatically types "K" every where inside anywhere i want to type.Pls i need a solution.
    Genius:
  • 2,028 Answers
First try pulling the K key off and check if the depressor is stuck. Be gentle and try to only remove the key and not the retainer. If the key is good, then remove the keyboard and clean the connector and the motherboard connection. This connection can sometimes work loose or get a Little dirt or corrosion build up. A this point, if everything checks good, then I afraid you have a faulty keyboard and it will need to be replaced..
Posted on Jul 18, 2008
My laptop keyboard can't work, its locked and i cant type
This can be done by software (locking the keyboard). I'd try a hard reboot, and see if that solves the problem.
If that doesn't work, sometimes keys get stuck down and cause the keyboard to stop working, it's odd but I find pressing (mashing) each of the keys 2-3 times will often fix keyboard issues. I typically start with the common keys like the ctrl, alt, shift, space, enter, etc.
Hope that gets ya moving again.
Apr 07, 2014 | Microsoft Office Professional 2007 Full...
I have a Toshiba Satellite A215-S7462 and the keyboard is acting weird. when I type and press H key it automatically goes in front of the last alphabet i type and when I press down up and side arrow keys...
This is caused by a short in the keyboard. Either something was spilled into the keyboard, or it was hit by a hard object.
Search EBay! for a replacement keyboard. Most of the time you can find them for $35-$50 and have a professional install it for you.
Aug 25, 2011 | Toshiba Satellite A215-S7462 Laptop
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
Inspiron 1525 laptop keyboard stuck
if you think thats the cause of the problem.... then you should clean it before it will cause more damage.
clean it with water and let it dry.
Feb 15, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Not sure if it a motherboard problem or not, but when typing,searching,etc, the letters won't print. I've lost question marks and some of my alphabet.
Power off your system. Unplug your keyboard, than re-connect it. Boot your system & test. (No help)! Try swapping out your keyboard with another. Still not working? Try a USB keyboard.
I doupt the motherboard or bios is causing this issue.
Cheers!
Mike
Sep 24, 2009 | PC Chips (M925G) Motherboard
The scroll number lock goes on by itself
you can just press function+num lock and then it'll turn off and on when you want it to
Mar 30, 2009 | HP Pavilion ze2000 Notebook
Keyboard mmmmmmmmmmmmmmmm
Might be a sticky key situation.  If you have patience and a steady hand, you can fix this yourself.  But, you need to figure out if the problem is with just one key, or a couple.  Sometimes, removing the one key that causes the problem and putting it back on again will fix it.  I would type in your model computer in google and look for a tutorial.  Something like http://www.fonerbooks.com/laptop15.htm will help.  If all else fails, it is not too costly to replace the keyboard itself.  (Simple installation, too)
Mar 05, 2009 | HP Compaq nx6110 PC Laptop
Wierd synbuls
You may have activated a shortcut key on your keyboard such as the Fn (function) key. It looks like this
Fn and usually situated on the bottom left hand side of your keyboard near the left hand cntrl button.
Some function keys when pressed once remain on. Once they are on they can cause different symbols to appear in place of the normal keyboard ones. If you press your Fn key again and then try typing on the keyboard once again it may help fix your problem.
I hope this helps
Cheers
john
Nov 16, 2008 | Compaq Keyboard
Power on password!
YOU should type your password then press enter or attach a usb keyboard then type
Oct 14, 2008 | HP Compaq Presario V2000 Notebook
HP NX9010 Notebook Logo
340 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
