Question about HP Pavilion dv6000z Notebook
Wifi connection i will be happily working on my computer and my wifi connection will disconnect. i have to re-boot my computer to receive a signal. i try to repair it, bridge it, turn up the distance and the broadband but the problem persists. is there any way that i can make my computer find a signal it has lost with out restarting my entire computer
    Genius:
  • 2,028 Answers
When you're loosing the signal the card is shutting down, rebooting resets the card, and there is no way of resetting the card that is any faster or easier than rebooting. This sounds like you may have a loose connection or a little dirt or corrosion built up on a connection. Remove the wireless card, clean the connections for the card and the two leads, also clean the leads and the card slot. Get everything seated back in good and try it. If you're still loosing the signal and the card shuts down, not letting you reacquire a signal, then the card is most likely malfunctioning, and will need to be replaced.
Posted on Jul 18, 2008
My zte z768g is showing wifi error. how can i fix that?
Make sure the wifi connection setup in your ZTE is still working, and you are close enough to the WiFi router to receive the signal. I assume the connection worked before.
Be aware WiFi can become bad when the router is not in the same room. Concrete walls are killers for WiFi signals.
Mar 27, 2015 | ZTE Cell Phones
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
My dell 470 wont boot up every thing seems to be working but when i turn on i get a blank screen and no signal displayed Edward
This means that your monitor is not receiving a signal from your graphics card.
Here are the things that you can try:
-Disconnect and reconnect your monitor from your computer.
-Try using a different cable to connect your monitor to your computer.
-Try connecting your monitor to another computer, if it works there it means that there's a problem with your graphics card and it may require a replacement. If your monitor is still saying no signal even if it has been connected to another computer that works fine then the problem is with the monitor.
Apr 22, 2011 | Dell Precision Workstation 470 (204816690)...
My laptop works using my Belkin router, but my desktop will not connect to the internet
hello
your notebook has WiFi, which is radio frequency internet, it transmits and receives radio signals (frequencies) . Your desktop, most likely, does not support WiFi on its own , so you need to use RG45 cable , ethernet cable to be connected from your desktop to the router.
So in other words thsi is what happens with your notebook and the router.
  1. your notebook has built in wireless adapter which translates data into a radio signal and transmits it using an antenna.
  2. A wireless router receives the signal and decodes it. The router sends the information to the Internet using a physical, wired Ethernet connection, to your modem (supplied by your Internet Service Provider)
The process also works in reverse, with the router receiving information from the Internet, translating it into a radio signal and sending it to the computer's wireless adapter.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
Nov 15, 2010 | Computers & Internet
How to go wireless on laptop
You need three things
1) An Internet service provider. Once you sign up and agree to pay the fee they will provide the internet service.
2) A wireless router. This is a unit that receives your internet service by through a connection to your telephone line. Then it transmits a radio signal (wireless signal) that your laptop can receive.
3) A Wifi card in your laptop or an external USB Wifi Dongle. This is a radio or wireless receiver that picks up the signal from your router.
The router is usually security protected with a keycode. All you need to do is set up your Wifi card or dongle with the same keycode and you will be able to receive the internet wirelessly.
To check to see whether your laptop has a Wifi card already installed, do the following:
Click Start>Programs>Accessories>Communications>Network Connections> and look for "Wireless Network Connection." If you have this, then your computer has a Wifi card installed and ready to go.
Aug 27, 2010 | Computers & Internet
The netgear is set up and the lights are on and i connected it but it says limted or no conectivity on the status and the signal is good so whats the problem
try right click on the computer icon near clock and go to status then to repair tab if this does not work try this;
if XP go to start button go to all programs accessories command prompt when it opens type in ipconfig/release hit ENTER
then type in ipconfig/renew
re-boot computer if this fails
disconnect power from modem, router and computer for at least 2 minutes turn on modem let it flash for about a minute then turn on router let it run for a minute then boot up computer.....
Jul 20, 2010 | NetGear WGR614 Wireless Router
We've got the Dlink DES-1008D setup in our office. Since the past 3 weeks, we've been facing disconnection problems. 5 desktop computers, all new and very recent, are connected to this. We've got an...
Ok, the next time when the disconnection occurs. Try the following:
Open command prompt. And try pinging www.google.com, if the ping is successful and you are still unable to access the internet, then you may want to check the proxy settings on your web broswer, or possibly repair/reinstall the browser. You can also try accessing the internet on a different browser.
If you are unable to ping google successfully, then try to ping the IP address of your wifi modem, this is your default gateway. If you are unable to ping this address successfully, then check the cable from the DES-1008D switch to the wifi modem. As a local area connection 'connected' just shows that the link from your PC to switch is fine.
Please try these steps and let me know the results.
Regards..
Apr 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
My d-link dwa-542 was working fine until the batteries went out in the wireless mouse. Since that time, the message on top of the icon says "disconnected". I tried unloading software and re-installing to...
It is highly unlikely that the flat mouse batteries had anything to do with the problems with your D-Link. I would try powering down both the router and range booster and then power them back up after waiting 15 seconds. If that doesn't work I would check that your netgear has a wireless signal and you can connect to the internet through that. If that is working OK, then I would see if you can log on to your D-Link range booster using wifi. If that works OK, then go to the setup section and make sure it is receiving the netgear wifi signal.
Dec 09, 2017 | D-Link DWA-542 (ASKU50237) Wireless...
Wifi access
Find the router and locate yourself as close as possible to it. If you are in the guest house and the router is in a main house, try opening a window or door if you can see the house out it, as wifi works better with less obstructions in between you and the access point.
May 05, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
