Question about OKI C5100n Laser Printer
Oki c5100 ; not printing anything, blank pages
We have recently replaced all drums, toners, and the belt. Now we get only blank pages out. no print, please help
flopez
  • 161 Answers
SOURCE: OKI C5100 only printing cyan
I need to know if the test page that the unit prints as "Demo Page" comes out fine. If this is the case, your problem is within your application (software) or computer connection (check all cables). If this is NOT the case, I'll need to know more about your scenario. Operating system, type of connection (USB, parallel) and what are you trying to print. I'll be waiting.
Posted on Oct 02, 2007
Soulvisitor
  • 1113 Answers
SOURCE: OKI c5100 Printing GREY instead of BLACK.
Check density control in COLOUR MENU is set to auto and exucute auto density in same menu, clean the led heads on the lid.
In MAINTENENCE menu you can increase paper black setting (ie+2).
If any of your non gen Toner got mixed in the new black drum then this is the real issue.
If paper has moisture in it toner doesn't stick as well, run it threw twice (first time it dries out) to confirm it is not a moisture issue
Posted on Jan 13, 2008
leroyal
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
SOURCE: drum light flashing
Try resetting the drum counter:
open the front cover, press the blue button and keep it pressed until all the LEDs are lit - hold for a few seconds and then close the front cover.
Posted on Mar 09, 2009
  • 1126 Answers
SOURCE: OKI c5100 flashing "K drum life" across screen. what does this mean?
"K" drum refers to Black drum Apparently the black drum has reached its life expectancy and needs to be replaced.
Posted on Jun 07, 2009
OKI C5100 printer Right side of printed page has repeat print. What do I have to do to get a clean copy without the duplicate print?
You have to determine if the drum cartridge or the fuser is the problem. Do a panic stop before the paper hits the fuser and see if it has the residual image. If it is clean then the fuser is the problem.
Feb 11, 2011 | OKI C5100 Laser Printer
Having problems with color, i have to print 5 copies to get a good copy, as the color just runs down page
Just solved the same problem. Mine was the fuser. It is either the drums or the fuser. Print something with color then turn machine off before it hits the fuser. If toner does not show up running before it hits the fuser. Then you fuser is bad~$100.00. If the toner runs before it hits the fuser then the drums are the culprit. If the fuser is bad, it will not heat the toner enough for it to stick to the paper then the unfused toner gets on the roller of the fuser and repeats the image or part of it in equal increments down the page.
Feb 19, 2010 | OKI C5100 Laser Printer
Oki C3100 - v poor print quality
Hi Errol
The way to identifiy your problem is to send a full colour print to your printer and open the top just as the paper starts to come out . if you then remove your toner / drums for all the colours you can see the transfer belt if the quality of the image that you can see on the transfer belt is good and clear your problem is with the transfer form the tranferbelt to the paper and not any toner /drum issue and the most likley cause is the transfer belt itself "but before you relpace it remove it and clean around the electrical contact points and generally make sure the internals of the printer is free of loose toner .
Regards Alan (Alstech)
May 13, 2009 | OKI C3100 Led Printer
Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Mar 16, 2009 | OKI C5100 Laser Printer
OKI Printer C5100 problems
probabily u have some message on the printer display, and your problem must be Toner low, u will ned to replace toner.
Jun 26, 2008 | OKI C5100n Laser Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Not able to print a status page. Tried holding down menu 5 sec and no output. I searched the menu and am not able to find how to print status page. I did print out a demo page and the black is great but when i print out text (like the entire menu map) the black is grey. Let me know if there is anything else I can do.
Jan 12, 2008 | OKI C5100n Laser Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Sep 27, 2007 | OKI C5100n Laser Printer
OKI C5100n Laser Printer Logo
239 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
