CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and, The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen. Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex. Note : flex can be found only on slide phones.
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND
A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check
1 screen control on eht transformer is mituned
2 supply to screen of crt
3 supply to rgb video output is absent
4 connector loose
5 crt base loose
thanks
