Question about Mercury P4VM800M7 Motherboard
Bios settings how do i get my computer to boot from cd
  • albrico Nov 14, 2008
    My boot order are: First hard disk and the second floppy disk. Where can I find the cd-rom boot?
  • cruzelis Dec 12, 2008
    In my case the BIOS seems it don't care of my modifications. After having saved and exited, the machine don't reboot, I have to power cycle it, and then restart with the old device boot sequence.
    What is wrong with my MOBO?
  • 144 Answers
Thats very simple..
At Startup - Press F2 / Del (Check ur mobo documentation) to enter into bios setup. Under the boot sequence - change the order of CD-ROM boot. Make CD-ROM as a first boot device. HDD-0 as second...
Hit F10, Press Yes & now system restarts. If it finds a bootbale CD, It will prompt you to hit any key to boot from CD..
Hope this helps you my friend...
Posted on Jul 18, 2008
4 Suggested Answers
  • 650 Answers
SOURCE: Where is the boot sequence setting in the Phoenix award bios
Try your function Numbers keys F2 F8 F9 F11 while you start the computer push the Function # If windows starts loading start over
Posted on Apr 08, 2010
  • 11 Answers
SOURCE: bios faulure
May be the battery on the motherboard needs replacing to power cmos when it's been switched off ?
Posted on Mar 27, 2008
SOURCE: Can not boot from cd rom...bios boot order is set
set your boot priority like this
1.DVD/cdrom 1
2.hard drive
thats works
Posted on Jan 21, 2010
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Vista will not load from CD
Your computer is probably set to boot to the Hard drive BEFORE the CD rom in the BIOS. Research how to access the "system configuration" or BIOS when your computer first turns on. Search through the BIOS menus and see if there's a place to set the "Boot Order". Change the boot order to boot to the CD Rom before the Hard drive.
Dec 16, 2011 | Computers & Internet
If your computer will not boot from the CD, be sure the CD is working.
Also be sure in the BIOS setup that you have told the computer that it should try to boot from the CD before it tries the hard drive. (You'll find that in the settings under boot order)
Sep 08, 2011 | HP Compaq d530 SFF PC Desktop
How can i boot my dell studio from cdrom so i can reinsall from external drive?
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 21, 2011 | Computers & Internet
How do I get my Toshiba Tecra to boot from CD
Please restart the computer and press the F2 Key to enter BIOS Setup. Then follow the onscreen instructions to locate the Menu for Boot Configuration to select First Boot Device as the CD-ROM Drive or DVD-ROM Drive. Then select F10 Key to save the changes and Exit. Now insert any bootable Operating System Disc and restart the computer to boot from the CD.
Mar 27, 2011 | Computers & Internet
I want to get in the bios to change the setting to boot from disk platform windows 7
  • Shut down your computer. Check your computer manual for the key stroke to get into your BIOS. Typically it is your "F1" or "F2" key.
  • Restart your computer.
  • Press the BIOS key that was indicated in your computer manual. Continue to press the key until the computer enters your BIOS.
  • Once entered in bios look for boot option and set primary boot device.
    Then restart your system
    Feb 20, 2011 | Acer Computers & Internet
    I have Intel 845 series motherboard & I want to format my PC but when I put xp cd inside & restarts & press enter the boot doesn't start now how could i format ?
    You have to change the BIOS settings to boot from your CD drive. It must have been set to boot from harddisk.
    To do this you have to change the primary boot device from Harddisk to CD drive. When you restart your computer press DEL or F12 or TAB or F1(any one...Depends on your BIOS see manual or try all) to bring bios. In bios go to boot device priority and set the CD drive to boot first.
    Restart your computer, it will boot from CD drive and XP setup will start.
    Hope this will help...cheers:)
    Sep 25, 2010 | Intel 845GE Motherboard
    How to boot to CDROM? unit: IBM Intel Pentium 4 1.8 ghz
    At power on, you should have an option to hit F12 or another key for boot options. From there choose CD/ROM
    Aug 08, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
    Why is my computer doesn't boot from cd even if i set the bios setting to boot from cd first?
    Will another computer boot from that CD?
    Disconnect the disk-drive, so that the computer cannot boot from it, and try again to boot from the CD.
    Is it possible that the CD-drive is failing, and cannot read *ANY* CD disks?
    Aug 02, 2010 | Samsung Computers & Internet
    Mercury P4VM800M7 Motherboard Logo
    293 people viewed this question
    Top Mercury Computers & Internet Experts
    Mark Gough
    Alun Cox
    Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
