Hi mate what I would is take the meter off altogether first make sure that you have the mains plug out then open up the meter an trace the mains connect you can disconnect these and reconnect the live and neutral with a ceramic connector our what I would personly do is replace the mains lead completely
Depends on the coin mechanism. If it's a coin slide that you put all 4 quarters in then push the slide back, then there are two solutions. First, and best, would be to fill the quarter slots with blanks, then you could just push the slide when you need to start it. Second would be to just take off the service door and you would be able to reach your hand in and push on the same mechanism the slide would, of course you would need to keep your hand away from any wiring to avoid a possible electric shock. If it's a coin drop, where you put one quarter in at a time and the unit counts the quarters as you put them in, then you wouldn't be able to just start it, but you could reprogram the board accept just one quarter instead of 4, and you would need the manual as each manufacturer has a different process to do that.
