Question about Whirlpool LDR3822HQ Electric Portable Dryer
LDR3822HQ When I plug in the dryer I hear a "buzz" sound. I am not able to get the dryer to do anything else.
  • 93 Answers
Possible bad motor, have an extra hand available door open hold door switch press start turn drum by hand see if it will turn.
Posted on Jul 18, 2008
Maytag gas dryer. Loud buzzing sound when flame comes on. Buzzing stops when gas valve off. Replaced solenoids twice. Dryer works but the buzzing is annoying. Do I need to replace gas valve assembly?
While you are hearing the buzzing, tap the gas valve (gently) to find out whether the buzzing changes. If so, the valve is the culprit.
Feb 18, 2017 | Maytag Dryers
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
White knight
take the plug
does it make a buzzing sound or do you hear the motor turning
or if you spin the drum by hand it spins freely if it spins freely check the belt and jockey wheels
Dec 08, 2013 | Washing Machines
How do I get to the door switch on a Whirlpool LDR3822HQ dryer
To access that door switch what ya need to do is firstly remove the top by removing the screws from the rear of it and slide the top toward the back then lift it off.then you see it the back side of the front panel at the top screws that hold the front panel to the remainder of the cabinet remove those screws and the front panel will come off where as ya can access the door switch.
GENE
Sep 30, 2011 | Whirlpool LDR3822HQ Electric Portable...
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
My dryer will not start. when i press the start button i hear a faint buzzing sound and nothing happens, the inside of my dryer warms up a little. other then the buzzing sound i hear no noise.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 31, 2011 | Dryers
Making buzzing sound and not turning. then the buzzing sound stops and it smells like something is burning. then u will hear a clicking noise and sound will stop all together and nothing will happen unless...
The motor on your dryer has gone bad. The humming is the motor trying to start and the smell is the motor getting hot because it is not starting.
You need to replace the motor.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 09, 2010 | Kenmore Dryers
When i turn for start i hear a buzzing sound and
Sounds like a potentially bad motor. When trying to start the dryer, it may have opened the thermal protector, which is why you are no longer getting the noise. Check that nothing is just stuck in the drum seal or blower wheel, seizing the motor. If all is clear, replace the motor.
Dec 30, 2009 | Electrolux Dryers
Dryer making a buzzing sound in the console but not running
Unplug the dryer.
Remove the rear panel.
Look on the exhaust vent for a failed fuse.
It will be narrow and about 1 and 1/2 inches long.
Remove the 2 wires and jump them together.
Plug in the dryer and start it.
If everything works OK replace the thermal fuse.
Feb 27, 2009 | Roper RES7646KQ Electric Dryer
Just buzzes
 the only thing you can do to possibly solve this problem without a professional is to:
  • tape down the door switch with strong tape, or have someone else hold it down.
  • physically turn the tub inside the dryer while pushing the start switch.
  • this will hopefully loosen whatever has the motor stuck.
if this does not work then the motor in the dryer might be bad or going bad, especially if a burning smell is present when you hear the humming sound.
Jul 25, 2008 | Hotpoint NVL333EY Electric Dryer
Whirlpool LDR3822HQ Electric Portable Dryer Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
