Question about Thomson Televison & Video
Thomson ifc130 chassis stuck in standby?
Thomson ifc130 chassis stuck in standby green led on, no sound, no picture, 12 volts ok 24 volts ok and standby 5 volts ok, no burning visable
no support in spanish wilderness much appreciate help.......have schematics
jerryg50
  • 1689 Answers
SOURCE: sanyo dp42746 low volt power problems
The power supply is failing, or there is another circuit area that is pulling too much current, and the supply is going in to protect mode.
This would require proper troubleshooting by an experienced tech. If the problem is very involved, or the tech is not familiar with the set, he will require the service manuals and service information.
Jerry G.
Posted on Apr 27, 2008
SOURCE: Hyundai HLT-3210 POWER SUPPLY FAULT LOW OUTPUT FROM SUPPLY PCB
Hello! My name is Ivica,and I am from Croatia.I have same LCD which have problem with motherboard.Try to disconect power supply from inverters and then measure all volt line.Maybe failure is on inverters board!Write me if you solve the problem,and maybe you know where can I find new motherboard for my LCD.Thanks.
Posted on Jan 24, 2009
satavlad
  • 405 Answers
SOURCE: Sharp AQUOS LC-46D85U green LEDs blinking, no picture, no sound
Sharp warranty is the way to go.
Posted on Oct 25, 2009
electronick
  • 505 Answers
SOURCE: I have a ViewSonic N3250W Television with
Does the LED kick on when you push the power button or when you apply power? Typically, the 5volts will run the microprocessor and that looks for a command (power button). When it sees a command, it will send a signal to the power supply to kick that on.. so at this point, you want to look for that signal. If you push power and no power on (p_on) signal goes to the supply, its likely your main board.. but if it does, and the supply doesn't react, then maybe its the power supply. I am not totally familiar with this tv, but thats how all of them really work. Even if the caps look good, some could be bad.. look for brands like "capXon, sanXon" are typically the defective ones, theres another but its slipping my mind.. usually 1000uf @ 16v are bad, or 2200uf @ 10v are also common.. you can search the value and the little code, usually like C9M or something and see if that batch has known issues..
let me know what you find, or how I can help
Posted on Jun 15, 2010
budmrtn
  • 11361 Answers
SOURCE: ViewSonic N3250W Television with FSP212-3F01.dead needs VOODOO
I am working on the same power supply right now, my has a bunch of bad caps that I already replaced but I did not try to turn it on yet becuase I see that RS1 and RS8 are missing, some one had try to fix this power supply. Can you please tell me the value of these two resistors? Please see my pictures at http://s807.photobucket.com/home/budm/allalbums
Your problem sound like the logic board problem, I can tell you what you should have if I can find out if these two resistors were left out from the factory or some had removed them. I fixed the same power supply for the N2652 but I did not take the pictures of the board, I wish I did.3a99fcd.jpg
Posted on Jun 27, 2010
RCA Model L40FHD41YX9 Will Not Power on. No Sound or Picture. Found cable from power supply to Backlight inverter connector burned. Replaced cable power supply and backlight inverter and main board.
Going by what all you have changed with no results its sounding like the actual CCFL lights are bad or at least one of them...there should be several sets of wires going to them from the inverter board, you can unhook them one at a time and see if you get some light on the screen, unfortunately though it sounds like the set may be on its way to the recycler. I assume if you look in the back of the set with the lights off you don't see any light.
Nov 08, 2017 | RCA Televison & Video
Why is the green led blinking on my M3N72-D motherboard
The flickering green LED on the motherboard is illuminated by the standby power supply, a small completely independent, always on, 5 volt power supply labeled 5VSB usually, output is on the violet wire.
Here's some more detailed instructions about how to check a PSU.
Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
Oct 11, 2013 | ASUS Computers & Internet
Troubleshooting
Tv has no picture, standby led light, output voltage from spms is 17,17,5,5 instead of 12, 12, 5, 5. Signal on/of from main board is ok, 3 volts. I do not know whether the voltage 17,17 culprit or it is ok. In the dark I can not see any pictures
May 27, 2013 | Philips 220TW9FB 22 in. LCD TV
Thomson 21"tv, with TX91 chassi, having picture
sounds like week signal. try on another aerial and retune.
Dec 22, 2010 | Thomson 21DC320 TV
Jun 17, 2010 | ViewSonic N3251w 32 in. LCD HDTV
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
Thompson 52jw643 is stuck in standby, when switch on red led appears, changes to yellow for approx 1-2 sec, sounds like trying to start and reverts to red. sometimes flashes red once. any help greatfully...
I have a similar problem with Thomson 52JW643 S in that it takes at least 12 to 16 attempts before it eventually turns on very very annoying !!!!!!! turns from red to yellow to green then back to red and then same again until she feels like switching on then perfect picture sound and quality ??????? can any one advise please
Jun 27, 2009 | Thomson Televison & Video
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Sony green power/standby led blinks picture goes out
I had this same problem and after doing some research, I removed the lamp, cleaned it and plugged it back in. It fixed my problem completely.
Mar 22, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
379 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
