Question about Orion TVDVD092 9 in. TV/DVD Combo
Orion TVDVD092, No Remote
I can't find the remote and I'm trying to navigate the menu on the DVD by using the buttons on the TV. How do I do that? Thank you!
    Problem Solver:
  • 4 Answers
Did you find your remote? i'm trying to get my orion tv to go into aux mode without a remote. do you know how to do that?
Posted on Sep 29, 2008
How can i hook up a dvd player to a Sylvain tv with no remote
Ok the brand of the tv is not as relevant as the particular model number as each set varies. generically speaking without having to ask you for more information, some tv set allow you to access auxiliary inputs without a remote by pressing a combination of buttons or repeatedly pressing the channel up or down button until the inputs are cycled. A lot of set also allow you to navigate through inputs by the menu, a menu is often accessible by buttons on the set. If none of these options are avaliable try contacting your tv manufactor and asking how to navigate the inputs Witout the remote, which keep in mind is highly possible that you may not be able to do so. Consider replacing the remote with a universal remote.
good luck and thanks
Questions? Just ask! Mr.Mike
Nov 17, 2015 | Televison & Video
Cannot change my TV to allow my new DVD/VCr to work
u can buy universal remote control for this options.
it will help you.
thanks.
Oct 28, 2008 | Televison & Video
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
How to set it up to universal remote
All the universal remote controls that I've had have come with a fairly comprehensive set of control codes for various appliances. If you don't have the manual you'll have to search online for a pdf relating to your universal which contains these codes.
Jun 29, 2015 | Orion TVDVD092 9 in. TV/DVD Combo
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Apr 13, 2015 | Sansui Televison & Video
The only functions the original remote for my Orion TVDVD092 performs is to turn the power on or off ocassionally. Is the proble with the remote or the sensor?
If the remote does even one function the receiver in the set is not the problem. It is possible if the remote is designed to program to another unit you have it in the wrong mode TV or Vcr or something other than your set.
May 23, 2012 | Orion TVDVD092 9 in. TV/DVD Combo
ORION STV2555 No Remote. How to change TV to DVD mode?
You must ahve its remote control to select input.
Apr 18, 2012 | Orion Televison & Video
How to program tvdvd092 without a remote
cannot be done---all essential controls are in the remote.
Mar 25, 2012 | Orion TVDVD092 9 in. TV/DVD Combo
I am trying to reprogram the channels available on an Orion TV VCR/VHS combo without a remote and no menu button on this device's face for access
Hello
It is impossible to make an auto tune function to this TV without its remote control, as there is no Menu button on its front panel. OK.
Nov 24, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
No sound on TV
You have turned on SAP sound. Switch your MTS TV sound back to main or standard or Stereo.
OK is used to choose your selection once you 'highlight' it with the arrow keys.
If you are having menu issues, unplug the TV for ten seconds, plug it back in and try the menu again. (you may have to reset your channels)
Feb 26, 2010 | RCA 3-Device Universal Remote with...
Orion TVDVD092 9 in. TV/DVD Combo Logo
438 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
