Question about HP Pavilion dv8000t Notebook
Unable to connect to internet.
We are using wireless.
I found the ip adress
how do I PING my router I don't understand what you mean.?
  • joycemann Jul 22, 2008
    well we tried that and it did not help.
    still can't get on the internet.
  • 57 Answers
Go to any working computer on your network.
go to start
command prompt
at the command prompt, type ping and your IP address.
2) or go to start
go to run
in the run box, typr cmd,
at the command prompt type ping and your ip address
Posted on Jul 21, 2008
Belkin f9k11009v1, Macintosh unable to connect
First see if you are able to connect to the internet wired to the router,
-If you are able to connect using the wire connection then I suggest to turn off the wireless security settings for the time being and see what happens.
See if you are able to ping your router.
-Make sure that the TCP/IP settings are set to DHCP and make sure that it is getting an IP address and Default Gateway.
If you are able to ping the router then see if you are able to ping google by name and by IP. (An IP address for google,com is
If you are able to ping both then you should be able to access the internet.
If you are able to ping only the google's IP address then you have a DNS issue.
-See if you can set your DNS address manualy to and Ref:
If you are able to ping only google by name then see if you are able to access google by typing in the replied IP address in the address bar of your web browser on a computer that is working fine.
-If you are not able to access google with the address then you may have something stooping you on your machine. Check for firewalls and antivirus to see if they have any network configurations.
Dec 18, 2012 | Belkin F5D7234-4 Router
It says it is connected to access point but internet cannot be found.
Check you connection by:
-checking connectivity to router
open command line and type :ipconfig" and hit enter
find entry called default gateway you need the ip it is set to
now in command prompt "ping GATEWAYIP" (replace GATEWAYIP with the ip from above)
If ping fails you need to check to make sure your router or adapter is not faulty. Or undo any static ip assignments you may have.
If it worked
try to run "ping" (this will test if router is routing to internet)
If it fails and the step above works you need to power cycle the router or replace if it dosen't work.
Now if everything works so far try this
if it fails you have a DNS problem you can fix this by useing goggles Free DNS server.
How to Link:
If that workes:
You may have a Internet explorer related issuse.
Fix by
Running a Virus Scan
Remove any IE toolbars
Clear all IE settings
IE toolbars: and IE settings:
Don't forget to Rate
May 10, 2011 | Linksys WUSB11 802.11b Wireless Adapter
Im trying to connect to a wireless network and it says it is connected but when i open the internet it does not work
check the configuration of your laptop. use another laptop to check the wireless configuration if its working in another laptop...check all possible setting of your laptop..make it fault all if needed
Jun 24, 2010 | Acer Aspire 5050-3242 Notebook
Connection issues
To troubleshoot the issue follow the below steps
1.Try disbaling and enabling the wireless lan card
2.Check whether Ip addresses assigned in the wireless network card.If the address is assigned by dhcp and not assigned in network card means assign static ip in the range supported in the networkand ping the website or gateway.
3.If the ip is assigned already means try pinging the gateway and dns server .If ping is success means the connection between router and pc and internet is good .In that case you have to check whether authentication is successful if any authentication is used.
May 10, 2010 | D-Link DIR-625 (790069292637) Wireless...
Network connected but no wireless internet
Please go to command prompt and type ipconfig /all. This will show you the dns adresses assigned to the etehrnet or wireless adapters. Try to ping that dns address. If you are not able to ping the dns address, assign static ip and dns addresses to the computers.
May 07, 2010 | NetGear RangeMax Premium Wireless-N...
My y450(418956q)laptop having problem that it
Ensure proper ip address is recieved from the wireless router
you can see the ip by typing ipconfig/all in the command prompt
ping the default gateway of router if ping is successful the router wireless connection is good
Ensure correct password is given when connecting to the internet if router is password protected.
try to ping webiste in command prompt like ping if reply comes means you can confirm that you is connected to internet
still no browsing means see any proxy setting in browser
Mar 04, 2010 | Lenovo IdeaPad Y450 Notebook
I have a D link router DIR 100 and since i have installed Service Pack 3 in my laptop, I am unable to browse internet. It shows wireless connection as connected but I am not able to browse anything....
Well te first thing you need to make sure that if you have the connectivity
To check this: Go to command prompt and than type ipconfig and see you get the right ip address or no if yes than
Try to ping website like in the command prompt type ping
if you are able to ping the websites that means you are connected to the internet and it's just a browser issue for that the best solution would be System restore which will remove the service pack 3 from the system and can fix the issue.
if you are not connected the the interenet than you ca try resetin your router iff need any clarification tha let me know.
I am assuming you understand about reseting router, ipconfig and all that.
Jul 29, 2009 | Computers & Internet
Unable to open internet page
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Jun 01, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = Subnet Mask = IP Adress = alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
HP Pavilion dv8000t Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
