Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Does not overwrite old codes, just keeps accepting new ones. How can I clear all existing codes?
    New Friend:
    Problem Solver:
  • 15 Answers
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Posted on May 14, 2011
SOURCE:
Why is my activation code not being accepted by mcafee. due for renewal
the code you are trying to put in should be only for the new program
old codes will not work for new programs
next , with most security programs you have to uninstall the existing program then install the new one and then put in the code
call mcfee help desk for assistance
May 08, 2016 | Mcafee 2009 Internet Security - 3 User...
Tip
Have you had problems with enabling FancyUrls in your CMS (Content Management...
Have you had problems with enabling FancyUrls in your CMS (Content Management System)? A lot of hosts don't have mod_rewrite enabled, or even a basic .htaccess file.
This simple fix is just clearly written to help users better understand what to do, as well as an easy copy/paste job.
  1. Simply copy and paste this code into a new Windows notepad file.
  2. "Save file as.." .htaccess - including the dot in front of htaccess.
  3. Upload the file to your public_html directory, overwriting the previous one if any.
  4. (Not a required step, use only if temp.htaccess exists.) If there is one called temp.htaccess, simply delete that one OR rename it as .htaccess and upload the new .htaccess for an overwrite.
Copy the text below this line..
AddDefaultCharset UTF-8
Options +FollowSymlinks
RewriteEngine on
RewriteBase /
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule /?([A-Za-z0-9-]+)/? $index.php?id=$1
# Add a ReWriteBase line to any directory or subdirectory requiring it.
# The default directory is "/", which is the root or main directory you use.
------------------------------------End copy
Good luck to you!
on Jul 04, 2010 | Computers & Internet
Tip
Simple Mod_Rewrite Codefix(Virtual Directory hosts only)
A lot of hosts don't have mod_rewrite enabled, or even a basic .htaccess file. Keep in mind this is for people using a blogging system or small Content Management System, such as Wordpress or GetSimple.
This fix is clearly written to help users better understand what to do, as well as an easy copy/paste job.
RewriteEngine on
RewriteBase /
Good luck to you!
on Jul 03, 2010 | Computers & Internet
Bought 2nd hand Curious village game, I want to clear the previous players
Simply start a new game and overwrite the existing save file when the game allows you to save
Oct 30, 2010 | Nintendo Professor Layton & the Curious...
How do delete a frequency code from my scanner i know how to program but dont know how to take a frequency off thanks
Just program 0.0 (zero point zero) into a channel to clear the existing frequency. Also, programming a new frequency into a channel will overwrite/delete the previously programmed freq.
Bill B
Aug 02, 2010 | Uniden BCT8 Base Scanner
Our Powerbolt 1000 will not delete old codes.
Are you certain you're programming new codes properly? It should just overwrite the codes when new ones are programmed. If you are doing it right, then I'd say you may want to have the unit repaired/replaced...
To program new codes (just in case):
Push the program button on the control board once for memory 1 OR twice for memory 2. Enter a 4-8 digit code. Push the lock button to end the entry. The unit will emit a 2-second long beep if your code is accepted. (If it doesn't beep, you were too slow. Try again.) Repeat the process for the other memory position.
Jan 30, 2010 | Weiser Lock Powerbolt 1000 Lock
Key in new contact info will overwrite other contacts
Hi friend,
You may check if you has set "overwrite existing",information about an old contact in the database will be overwrite by the new contact information if you set this,
And may be you used the same name....you can get more information in our website:http://www.1010store.com,it's not an advertisement,it may help you.
Good luck!!!
Aug 25, 2009 | LG Xenon GR500 Cell Phone
Caller id stoped working I dont know how to clear the old numbers
You're right. The CID buffer is 300. Now, somewhere there's a command to let new calls overwrite the old. Hmmm, why is that?
That's just the buffer size. From the attendant phone on intercom, dial 7373# and the Display will say Incoming Call Log ON. That lets the 301's call overwrite (7372# does not).
THis is the command set for a TA-824. It may be different if you have a TA-624, TAW-848, or any other sytsem that the 7731 may be plugged into.
Carl
Jun 22, 2009 | Panasonic KX-T7731 Corded Phone
CHANGING OPERATING SYSTEM: VISTA TO WINDOW7 TRIAL VERSION
Keep the old system . Instal the new one leaving the old intact. Thsi is called a dual boot. When you turn it on it will give you the option of which version to run.  When insstall the new OS Beta  it shoudl give you the options of :"Overwrite windows?" Say no.  Then go ahead and install.    As to the question about your existing windows. Ifyou have not the reinstall cd's or the reinstal someone else on your hard driver, and you loose you present windows. You will usually have to purchase either the reinstal cd's or a new windows version.   I myself,of would make sure to have or make them before instaling anything else.
Jan 24, 2009 | HP Pavilion dv6000z Notebook
Software
It's called a reinstall and yes you can. The preferred method is to completely wipe off the original software and then install the new one. If there is going to be a problem installing over the same software, the installation process will usually be aware of the existing software and either overwrite it or say it will remove the old one first for you.
Jan 19, 2008 | Ovens
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
627 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Azam Ali
Level 1 Expert
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
