Question about Lands Phones
How do i listen to my messages while im roaming
Just stop roaming for a short perioud of time, then lesten to them, then you can rewsume roming
Posted on Aug 01, 2008
Is my cell phone supposed to roaming, I get messages that saysYOU ARE ROAMING DATA ROAMING; you have losrdata connectivity Theres a smaal letter R at my signal strength,
  • R = roaming as you found out
  • E = Edge, or 2g...its really slow but works in a pinch
  • 3G = 3g...still slow but better than Edge
  • H = HSPA, its a form of 3G just a lot faster...this was considered 4g before true 4g
  • H+ = HSPA+, same as above just faster
  • LTE = 4g LTE. its the fastest of the bunch.
R is for roaming. Maybe your network doesn't allow data on roaming?
Nov 26, 2016 | Cell Phones
Why does my text messages not go to Jamica from Ireland or do i have to have roaming ?
The international code should be 001876.......
what does it say when you have sent the text??
Check the message details on the sent message, or does it
stay in the outbox? Can you make calls to Jamaica??
Sep 06, 2014 | Nokia Cell Phones
How to disable roaming on a Samsung phone model# SPHM9SO ? Im using virgin mobile service.
Hi Cyndi,
I have this site for you on how to do disable roaming. It includes image on how to do it. Hope it helps.
How to turn data services and data roaming on off on my Samsung Galaxy...
May 02, 2014 | Cell Phones
My whatsapp messages wont send
first go to whatsapp then settings n then go to the network setting and enable your roaming...try it ..it wil start working
Aug 16, 2012 | Nokia E63 Cell Phone
Before i left the philippines i activated my smart buddy on roamin...i typed in roam on and sent it to 333...i then recieved a message saying the roaming services will be activated shortly but when i got...
you can buy a pay as you go sim card from an english provider, and call your relatives from that card.in this way your cost will be cut, cuz you dont have to pay the so expensive roaming tarifs
May 11, 2011 | Cell Phones
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
Cant enter the repair shop
You're not supposed to do anything but drive around in free roam mode to learn where everything is at. If the problem persists and goes into the career mode then I would have your disc resurfaced. That might also fix any problems you are unaware of.
Jun 08, 2009 | EA - Electronic Arts Need for Speed : Most...
My lg phone says im roaming when im not and it wont let me send out text's or recieve
Your phone is programmed with parameters to trancieve from a particular network. It roams when you're outside the coverage area or when the programming parameters have been altered in some way. Check your settings or refer to the network's programming unit to have the parameters entered correctly... then you'll be connected to the network services.
May 04, 2009 | LG ALLTEL AX275 Cellular Phone
How do you turn of phone - no calls and turn off just roaming?
Enable Airplane Mode on your iPhone by choosing Settings, then turn airplane mode off.
This will disable the ability to:
Make phone calls
Send or receive email
Browse the Internet
Send or receive text messages
Stream YouTube videos
Get stock quotes
Get maps locations
Get weather reports
When in airplane mode you can still:
Listen to music and watch video
Listen to visual voicemail
Check your calendar
Take or view pictures
Hear alarms
Use the stopwatch or timer
Use the calculator
Take notes
Read text messages and email messages already stored
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | Apple iPhone 3G
GPRS Network not available...help
hello,
normally this error would cause if your in Analog Roaming area, i also have seen this error, when one travels through a Analog Roaming area, and Data portion of cell phone will get stuck with Analog Roaming Tower, when ur back with in Digital Roam Area this should go away, if not call your service provider and have them reset your data Signal from Analog Tower.
hope this information will help you.
Ty
Dec 21, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Lands Phones Logo
47 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
