Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis he, ld flashing at 8min.
My machine runs fine until the last 8 mins. It starts flashing ld, and will do this until i turn it off. I've tried the " rinse&spin" and the CLEAN cycles, but the same thing happens. What do I do?
  • 3 more comments
  • charlynn Jul 22, 2008
    Does ld flashing code stand for LID or LONG DRAIN? I've been told both...My machine works fine until the last 8 mins, then ld starts flashing, and it will not go into the final spin.
  • 104WILLIAMS Jul 26, 2008
    I have the same exact problem. At 8 minutes it stops. I can't get the close to the final spin. I've tried uplugging which sometimes resets and I can get a load in. HELP
  • Anonymous Jul 28, 2008
    My kenmore oasis he washer startes flashing LD at 20 minutes. The clothes are soaked and it will not go into the final spin. Every button I push seems to start the wash cycle over.
  • Tracy Brightwell-Kraft Aug 01, 2008
    Mine started doing this exact same thing tonight. I cannot get it to do anything! I unplugged it finally and plugged it back in. Tried to just start the whole cycle over and it acted like it wasn't ever going to stop filling, so I shut it off... by unplugging it again! Help please!!
  • Anonymous Aug 02, 2008
    Ld is NOT lid. Ld is "the machine is taking too long to drain". It says to check for a kinked or blocked drainage hose...
We have had the LD light come on when the water pump is blocked. This has happened twice in the last 4 months (11 month old washer). Water has remained in the tub in these scenarios. According to the repair men, the first time it was a small pebble and the second time it was a bathing suit top that plugged the water pump. Not sure how a pebble and bathing suit top is getting any where close to the water pump. We are not jamming too many clothes in the washer either. We fill it to the point where we still see a little metal from the tub (blow the plastic rim). From what I can tell, there seems to be a design problem with this machine.. By the way, we had water spilling out from the bottom rear of the machine over the weekend. The repair man said a hose popped off. My advice to buy the warranty and stay close to the machine when it is washing....
Posted on Aug 05, 2008
  • 95 Answers
Sounds like a bad lid switch. Many times you can test these by using a small jumper wire to connect the two wires on the switch it's self.
Posted on Jul 21, 2008
How do I unclog the long drain Kenmore elite oasis?
Honestly, we got rid of the machine and bought a Maytag Neptune. I was over trying to figure out all the codes the Oasis was flashing. We gave up on the first one that started having problems when a friend gave us one identical to ours and it has done a lot of the same things.
Apr 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have the kenmore oasis he toploader. It keeps shutting off shortly after the water starts to fill and then it flashes ld. I am assuming that it is the lid lock. It will not start again. This washer...
i have the same one and have had the same proble last time i had someone out to fix it it was flashing ld as well it ended up having a pieice of clothing stuck betweeen the drum and the indise of the washer. its also flashed ud and it had a penny stuck in the water hose so i feel your pain. but you might want to check and see if there is something that some how got stuck on the out side of the drum hope this helps
Dec 27, 2010 | Kenmore Oasis HE 27062 Top Load Washer
My washer stops in the middle of the cycle what does this mean Flashes LD Error
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine stops half way thru and flashes code LD?
Long Drain
Ld flashes when the water level does not change after the drain
pump is on.
Is the drain hose clogged?
Is the drain hose height greater than 96′?
Is the pump running? If not, see TEST #7, page 13.
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis won't completely drain and flashes "LD"
Does the pump keep running and then shut off first if so you can try this .It is not the proper way but sometimes you have to wait for the machine to go into the spin drain cycle and tilt it gently a few times like an old pinball machine. I sometimes have to do that. but I want you to know it is not the best for the machine you could break something else while doing this
Dec 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Error Code LD flashes
Today (4/3/09) I got a letter from Sears. They will replace the electronic control board (you know, the F-51 business) for FREE, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083. The voices of all of us have finally been heard!
Feb 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Ld code, will not drain, will not turn off
there is something stuck in your pump remove the back panel and you should check the drain pump the pump that is on the bottom left. good luck
Jan 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
112 people viewed this question
Sal De
fordexpert
Robert Rankin
