Question about Cameras
Error message on san disk sd card
Have used my san disk extreme III SD card for about 2 years.
it has been formatted (in the camera) quite a few times with no problems.
now, after formatting i got a "memory card error" notice in my camera.
when i put in a brand new card, there was no problem.
did it just die of old age or something else ??!!
thanks for your help.
    Problem Solver:
  • 7 Answers
You may have answered your own question. There is a good chance that your memory card has reached the end of its life. You might try reformatting the card with the computer and then do the format in the camera. This has worked for me before.
Posted on Nov 02, 2008
San Disk Extreme 8GB with Images on but no images on computer
Check the camera's settings, the photos maybe stored in the camera's internal memory and not being stored on the memory card.
Apr 21, 2013 | Sony Alpha DSLR-A350 Digital Camera
I keep getting card cannot be used every time i put a memory card in my nikon coolpix s210 what can i do to fix this
If formatting does not work then most likely the memory card id faulty.
Memory cards such as SD and USB memory sticks do not last forever. they do fail eventually after many writes and file file deletes or damaged by not using Safely Remove Hardware on the computer.
Jun 11, 2012 | Nikon Coolpix S210 Digital Camera
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
Cannot use the San Disk 4 GB flashdrive
up to 2gb sd cards are sd format 4gb are sdhc format . you camera will not write to sdhc and it is not a good idea to put in your camera .
Jun 03, 2009 | Nikon Coolpix 2200 Digital Camera
Can't format 2Gb Extreme III SD card in Canon G9 camera
Did you try formating with the Camera? Before that, Try formating with Windows Disk manager, then format with the camera, It will solve the problem.
Nov 01, 2007 | SanDisk Memory Media
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Cameras Logo
209 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
