Cool down first the unit for about 5mins.Disconnect all input and the speakers connected to isolate the problem. Power it on then observe while playing it naked. If the symptom still there then I've suspect that you have a fault on the FF:
1. Power supply - might have an unregulated supply caused by leaky capacitor.
2. Pre-amplifier circuit - might be faulty.
3. Output IC - IC is leaky which overheat after a minute which trigger the unit to protect.
This is not diy and need to send to repair shop.
If the symptom gone after you played it naked then I've suspect the ff:
1. Short on speaker wire.
2. Short on speaker voice coil.
3. Short on input.
Thanks for using fixya.
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
