1997 Pontiac Sunfire Logo
Posted on Sep 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much should it cost to replace the ignition wiring harness located in the stering column? Its on a 1997 Pontiac Sunfire SE. When I turn the key nothing happens but everything else in the car works. A mechanic said it was the starter and the ignition wiring harness in the stering column. I know a starter cost right around $95 dollers but what about the wiring harness?
deton8 von Splosion
Level 3:
  • Pontiac Master 3,342 Answers
  • Posted on Sep 04, 2017
deton8 von Splosion
Pontiac Master
Level 3:
Answers
3342
Questions
6
Helped
928653
Points
54123
Not terribly specific... Jerry2bud,
Second opinion time...!!
There are PRECISE parts in your IGNITION SYSTEM
that should be looked at for "no start" condition"...
but I whole heartedly agree with JEFF ARMER...!
How much... ??
With your current mechanic
A WHOLE LOT more than it ought...
Look here...
BBB Industries...
BBB Industries Premium Alternators Starters Power Steering Products
and here
1997 PONTIAC SUNFIRE 2 2L L4 Steering Column Connector RockAuto
More Information for DORMAN 924708
More Information for ACDELCO 12092163
Replace the harness... HOG-WASH (in my opinion).
Carnac the Magnificent
Jeff Armer
Level 3:
  • Pontiac Master 15,575 Answers
  • Posted on Sep 03, 2017
Jeff Armer
Pontiac Master
Level 3:
Answers
15575
Questions
Helped
7110153
Points
73899
Ignition switch . not wiring harness . I would try a different mechanic .
5 Related Answers
A
Anonymous
  • Posted on Sep 05, 2008
SOURCE: The key wont turn in
if its an 04 theres a button you have to push on the ignition wile you turn the key you should be able to push it with your thumb wile turning the key its meant to prevent children from acdentally starting the viehcle this likely is your problem if you have not solved it allready
Anonymous
  • 1990 Answers
  • Posted on Jan 22, 2009
SOURCE: 2002 pontiac grand Am
Replce the Starter Relay in the Fuse Box under the Hood.
Anonymous
  • Posted on Feb 15, 2009
SOURCE: pontiac sunfire
I had that problem last year. I bought a new starter but it was not the correct one for my car. For the 98 there are two different starters. I bought the wrong one the first time. My step father started to put it one and realized it was not the same as the one he just pulled off. Ending up taking it with us when we returned the orginial one I bought. The orginial one I bought was about $70 the correct one was $400. The auto store did not have the correct one listed as a replacement part. Until the number off of the part was keyed into the system and found out that it was just not the common replacement part.
gordanddar
gord storey
  • 477 Answers
  • Posted on May 05, 2009
SOURCE: 96 pontiac sunfire wont start.....
Starter solenoid , or wire that leads to it.
Also , if standard transmission , may be the switch on clutch pedal is intermitant.
Engine won't turn over unless it thinks you have your foot on the clutch.
Roger Foster
  • 701 Answers
  • Posted on May 06, 2009
SOURCE: need location of crank angle sensor on 1997 pontiac sunfire 2.2 liter
Hello oldiro: My name is Roger and I can help. From under the vehicle look up between the transmission and the side of the block. Mid motor above the pan rail there is a bolted in sensor. This should be the crank sensor.It will have two wires plugged in to it. Please rate this answer as this lets us know you received the information you asked for. Should you need further help please just ask. Thank You for using FixYa. Roger
Where is the Theft deterrent module located on a 1997 Bonneville?
How did you determine that ? Have a factory scan tool an check data parameters ? Do electrical testing ? If you don't know where it is how could possiably test it . The most common problems with this anti-theft system is that the wires coming from the ignition switch break . There are contacts inside the ignition cylinder that read the resistance of the pellet on the key . If you look under the dash on or around the steering column ,find wiring for the ignition lock cylinder . Should have two white wires inside a yellow or orange sheathing . Check resistance of the pellet on the key ! Stick the key in the ignition ,now check resistance at the wires . If read no resistance , a wire is open . You can buy a resistor of same value an solder into the harness . Not the ignition cylinder side .
2answers
How do i replace a ignition lock cylinder on a
Not really a job for a non-mechanic. Column covers off, switches out of the way, wiring disconnected, column dropped down under the dash, bolts chiseled out, big job.
Fob lost and antitheft wont let me start pontiac sunfire
Locate the immobilizer unit. This is a black box, usually situated under the dash close to the steering column. Trace the wires from the immobilizer to the vehicle's wiring harness, and where the original harness was cut, remove the immobilizer wires, and reconnect the original wires. Most fitters simply disable the ignition or starter circuit at the ignition lock wiring and this can easily be reversed.
A professional repair centre or auto electrician may only take less than half an hour for a job like this.
How much would it cost to get new 1997 pontiace sunfire made
It is cheaper to call your local towing company and ask them to unlock it so you can get the key you left in the ignition out. $20.
2answers
How to replace steering column in '02 pontiac sunfire
Your best bet ,take it to a qualified repair shop . you will have anti-theft system problems .
I have a 1997 Pontiac Sunfire. we pulled the key out of ignition without the car in park. the cover "Button" on shifter had gotten stuck under it. now the Steering wheel is locked, the Key will...
The key is most likely OK. So is the shifter. I would bet a $100.00 (that I can't cover) that the shifter is in a console "on the center of the floor". If so, the "electric/mechanical switch that you key cylinder actuates when it turns is on the top of the steering column, above the brake pedal. You will have to drop the column down with the 2 1/2 nuts, holding the column up to the dash, after the plastic cowls are removed. It will have a cable, that goes from the "electrical" switch, to the console. to activate/deactivate, the button on the shifter that depresses. Once it breaks, usually cloumn will lock "open" or "locked" .......no in between.
1helpful
2answers
I Have a 1997 pontiac sunfire se, automatic trans., 2.4 engine, whith theft light on and it wont start, what do I do.
try relocking your driver door and unlocking wit the key.sounds stupid but this how most security systems are overridden.
Can not turn key 1997sunfire but can take out of ignition
Sounds like the lock tumbler is bad...If it is the one I'm thinking of it is fairly easy to replace...if it has a small wire harness on it you will need to re-arm the security system after replacement by leaving the key in the "on" position for 15-20min 'till the light stops flashing before you can start it.To get it out though, you may need to wiggle the key around 'till you get to turn. Check a manual and take a look at it by removing plastic column shroud, to make sure it is accessible.
Changing ignition on my 02 sunfire
remove the stering columns plastic covers & it will expose the ignition lock
unplug the wiring loom & unbolt it [2 bolts]
they ma be original bolts that the head breaks off so you cant unbolt the [antitheft system]
if they are then you will neeed a steel punch & hammer to start them turning out!
Cheers Rob
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
