Question about Whirlpool Washing Machines
Top loading whirlpool leaks during drain cycles. Back hoses are ok. Of the two visible drive belts at the bottom, one is fairly slack (not the belt coming off the motor, the other one). Should both belts be tight?
  • 57 Answers
Hi mate the answer to your question is that all belts should be tight but could be a clue to your fault where the belt is slack check to see if there is bushing is worn see if there is play on the shaft if so replace the unit
Posted on Jul 18, 2008
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
My whirlpool top load washer is leaking out the front side, no hoses are leaking.
Hello there:
Your washer can develop several types of leaks. I will post this solution in 2 seperate posts for you ok?
You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
May 26, 2010 | Whirlpool Washing Machines
There is a leak at bottom of washer what can it be?
Hello, The water pump recirculates water during the wash cycle and pumps it out for the spin cycle. Some washers use the recirculation to mix and distribute add-ins like bleach or fabric softener. In some models the spin cycle starts while the water is still in the tub; others drain first before the spin cycle starts.
For the the initial filling of the tub, the pump is not involved. Filling the tub is the job of the water inlet valve. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added.
There are two types of pumps; direct drive and belt drive. The direct drive is mounted directly to the motor, the belt drive is mounted to the chassis. The direct drive style can be opened for complete inspection while belt drive models may or may not be designed to be opened. You can however, still remove the hoses and inspect the ports for a blockage or loose connections that may be causing a leak. Inspecting the pump is fairly easy to do, but you will most likely have to open the washer's cabinet.
Typically one of three problems occur with the pump. The first is a blockage in the pump, often from small items like a sock. The second possibility is that the impeller blades become broken or worn down and cannot move water efficiently. Next, in belt drive models, if the belt is loose or broken it does not turn the pump. Finally, Your pump may leak if there is a loose hose or cracked pump housing.In this case, it must be replaced.
Locate the pump, it will have two, three or four hoses. Label each hose and where it connects. The hoses should each have a wire clamp or a hose clamp with a screw. Pinch the wire tabs together with pliers and wiggle the clamp farther up the hose. Screw style hose clamps are simply loosened by turning the screw, then slide the clamp up the hose. Now remove the hose from the port.
Direct drive pumps have metal clips that hold the cover plate unto the pump assembly. Use a screwdriver to pry up the clips and remove the cover. Pull off the pump's impeller unit and inspect for damage.
Belt drive pumps vary and may or may not be designed to open for repair. Examine the pump to determine whether it can be opened. If it cannot be opened, look into the ports for any blockage.
If there are no blockages, the actual leak may be in a damaged hose or pump housing may be compromised. check all hoses for good connections and good hose integrity. if the hoses are not leaking, replace the pump.
Thanks
May 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer just started leaking out of the bottom-
Dec 18, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
My Maytag washer is leaking during fill up. The hoses are fine. The leak is coming from under the washer.
Oct 28, 2009 | Maytag MAT13MN Top Load Washer
Pump works. Spins when empty/no load in tub. clutch slips when loaded
If the drive belt is slipping during the agitate and both spin cycles for loaded conditions, I suspect that the drive belt is excessively worn. If it slipped only during a loaded spin cycle, I would have suspected that the sliding motor mount is gummed up and not moving to a belt tighten position during the start of a spin cycle. Since the unit drains with no problem for loaded and unloaded conditions, the pump belt should be OK. Replace the drive belt and clean the dust, gunk, detergent, etc, out of the sliding mount to make sure that it tightens properly when a loaded spin cycle starts. Note that on most models, the drive belt is designed to slip when spin cycles first engage, and they will continue to slip until after the drum has accelerated.
Sep 23, 2009 | Whirlpool LSR5132PQ Top Load Washer
I have a twenty year old Maytag washing machine that is leaking water out of the bottom of the machine. I have checked the hoses and it is not coming from there. Any ideas
hello. i can help you. unfortunately, your problem has numerous possible causes.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 02, 2009 | Washing Machines
Whirlpool washing machine stops after wash cycle. Will not drain for rinse cycle
Check the following to address this issue. if all checks out ok, replace the timer/control.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
