I have just installed the BD C5900 and have exactly the same problem. Spoke to Samsung and they say your have to switch the blu-ray off and on the front of the blu-ray player itself press and hold the stop button for approx 30 seconds (small square symbol). This is a master reset. You then follow the set-up procedure as you did when you first installed the blu-ray. I did this and mine works fine now and has the latest software version BSP-C5900WWB-1009.1 installed okay now, and everything including internet accessable once again..
SOURCE: Hi, I have a Samsung
Turn your BD on without cd in it, wait until appear no disk on screen.
Use this combination : Repeat-5-6-7-3-2-9
You should seen "9" on right of screen.
Good luck.
SOURCE: bu-ray will not read blu-ray dvd's
Reason it won't play blu-ray's now is because the laser is to weak. The laser requires a different strength to read the diffferent discs and if the laser is weak in any way then it will error out or freeze up. Either way you'll have to get a new player cause you cant get parts for it.
SOURCE: my samsung bd-p1500 blu-ray player won't play
I'm having the same problem. had my Blu-ray and my cable box plugged into my reciever. Blu-ray kept cutting out and not finding a signal while watching my Rome DVDs. I swapped HDMI cables by just switch which cable went out of my blu-ray ( I didn't change what ports they were plugged into on the reciever. That cleared up that problem. I'd assume it was a faulty HDMI cable except that it works fine on the cable box. Anyways, we were watching Iron Man on Blue-Ray and it starts to skip about 2 thirds through the movie. Same as you I updated the firmware, disabled BC-Live, No luck Don't know if the problem is hte Bluray player , the reciever or what. Everything is up to date so I don't get it at all.
SOURCE: BD-HP21U problems playing discs
You have inadvertently downloaded the US (or other region) version of the firmware. Unfortunately if you try and download the UK version the HP21 just tells you you have already installed it. I was told mine the only way to reset it is for it to be sent to Sharp or you can wait for a new firmware update.
Ok i think I have fixed the problem after a month of problems. I read somewhere if you press and hold the stop button on the player (not remote) for 5 seconds it resets everything. Any data you had downloaded or accounts created are wiped which is annoying, but atleast it now works.
