Hi there. Every so often i cant get a page and i have noticed this coincides with the question mark on my router flashing yellow. This is usually worse at night. Thanks...
    Problem Solver:
  • 7 Answers
This is because of network congestion. Although a physical line is run into your house to access the internet, that physical line runs into another line that other people in your neighborhood use. When alot of people are on you will experience slowness and possibly disconnects from the internet. Night time is typically peak time for internet use. This is fairly normal. There are ISP alternatives however that may allow for a quicker speeds for you.
Posted on Jul 18, 2008
  • 149 Answers
Night time is usually when everybody is updating thier websites so that might be the problem. Also, the router may be having updates being issued by the provider
Pc wont reconize router
click start control panel view your network and status tasks there should be all sorts of options connect or disonnect a local area connection with a diagnose option and a troubleshoot option
with other options on left side panel internet options windows firewall
might need a driver update
click start right click on computer select properties device manager at top of list scroll to network adapters if you see a yellow question exclamation mark ? ! or a red X a new driver willneedto be updated/installed
if your computer came with a motherboard disk the drivers could be on it
hope ths helps
Nov 12, 2011 | Computers & Internet
Bit of a long story but Ill point form it: - Yesterday I noticed the Wifi was not working on the laptop. Thought it was just being stupid because it is an old laptop - Today my brothers XBox 360 cant...
Not logging into the router could be due to the IP address to log into it change after resetting the router. As for the wifi not working make sue that the deices are using the correct security settings. Remember older devices are not compatible with WPA and uses WEP.
Mar 28, 2011 | U.S. Robotics (USR8054) Router
Hi, my Toshiba NB 200 won't connect to the internet, says reset router, server says router is fine and I have reset it but still won't connect. Running Windows 7
Try disabling Firewall and check the status. If it solves the problem then configure Allow Incomping and Outgoing option for the Router.
If Not, please provide me the following details:
1> Router Make.
2> Are you able to ping to the routers default IP?
3> Do you have Admin access in the system?
4> What happens when you use any other form of Internet. EX: Ethernet, Modem
5> Do you notice any yellow exclamatory Marks in Windows device manager list for Network adapters?
Nov 30, 2010 | Toshiba Computers & Internet
How do I clean the bean grinder in a seaco royal profesionla machine?
These instructions come directly from the service manual. Notice the mention of a qualified technician. If you do this on your own be careful. If you don't follow the instructions correctly or you break something you've will have no one to blame but yourself.
-Clean the coffee beans container periodically; this operation should be accomplished by a qualified technician! Unplug the machine. Empty the coffee container and unloose the two fastening screws. Now, the container can be removed and cleaned.
-Carefully pull the adjustment lever upwards, previously writing the set grinding degree.
-Turn the adjustment ring counterclockwise, until the blue marks coincide.
-Now, it is possible to remove the grinding ring from the machine, slightly pulling it upwards.
-With the aid of a brush or a narrow vacuum hose, clean both the gear box and the grind ring support. Make sure the position of the grind ring does not shift. To reassemble the coffee grinder, carry out the reverse sequence, making sure the adjustment ring has not been shifted during cleaning. If that is the case, turn it until the blue mark coincide with one of the three notches. Assemble the grind ring support and make sure the blue marks coincide.
-Turn the adjustment ring clockwise, to make the red marks coincide.
-Fit the adjustment lever on the ring, until it coincides with the previously set grinding degree.
Nov 28, 2010 | Saeco Royal Professional Espresso Machine
Hi. I cant seem to be able to log into my router settings. I press login but nothing happens.It just stays on the log in page
Try to reset the router to factory settings.Locate a small hole at the sides or back on the router.With a toothpick press the button until the router flash lights start.The try to start a new configuration.
Nov 15, 2010 | Zyxel Prestige 600WH Wireless Router...
I don't know the previous password. how do i reset it?
download the manual from the given link. which contains procedure for the same.
http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/
Please rate the answer... Thanks......
Jun 22, 2010 | Linksys Wireless-G WRT54G Router
What does the yello camera with the yello
I have an S1000fd and to get rid of the yellow camera icon with the exclamation mark next to it I pushed the button on the side of the flash to pop the flash up. Its a low light level indicator basically.
Aug 10, 2009 | Fuji FinePix S1000FD Digital Camera
Unable to access internet through router netgear ga311
Try to remove the adapter to the computer. Uninstall and reinstall the driver before installing the adapter to the computer.
Note. if you got the same problem as before download the latest driver of the adapter then try to reinstall the driver again.
Mar 24, 2009 | NetGear GA311 Network Adapter
Yellow Logo missing
The first thing to check to see if a site is secure, check the URL and make sure it reads:
https://www
If there is no S after the http then someone is trying to get you to input your password.
(the letter "s" indicates a secure site)
Mar 24, 2009 | Microsoft Windows XP Professional for PC
I cant go back to defaults in my zyxel hs 100 w router, so i my conectivity is limited or nule what can i do??????
To perform a factory reset:
Power off the router,
Hold down the recessed reset button on the rear of the unit (keep it held down)
Power on the router with the reset button still pressed down.
You will notice all the LAN lights flash at the same time which will indicate that the router has reset - this takes up to 30 seconds.
When all the LAN lights do flash simultaneously you can let go of the reset button.
Your router is now reset.
The default IP address is "192.168.1.1" and the default password is "1234".
Now, do set the admin password again, other vice others can access your router and change the setup and set the password.
Regards
/Teis
Jan 03, 2009 | Zyxel HomeSafe HS-100W Wireless Router...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
