Question about Maytag Neptune MAH5500B Front Load Washer
Mold and mildew in the Maytag Neptune MAH5500
I have mold and mildew odors in my machine. The boot also has a tear in it. How difficult is it to replace the boot myself? And how can I avoid mold problems in the future? Leaving the door ajar does not do the trick...I must leave it wide open. Not pleasant to look at,
    Scholar:
  • 50 Answers
The new boot has an anit-mildew treatment and should resist any new mold. Also, you should always use the hottest water possible for your clothes, the hot water helps kill the bacteria that causes the odor. Also bleach will kill the bacteria and you should use bleach whenever possible. If you don't like to use bleach on your clothes, or have an allergy to it, then once a month, run the washer without any clothes on the normal cycle, hot wash, and put bleach in the soap dispenser and let the washer clean itself out. The boot is fairly easy to replace except for a spring that holds the boot to the tub front. The spring has a lot of tension, so it is difficult to hold both ends of the band and one end of the spring tight enough while streching it. I usually do it with a pair of vise grips and a pair of pliers, but I've replaced dozens of boots. You may need an extra hand to help with your first one. Other than that, if you pay close attention to how it came apart, and align the all the slots on the boot to the tabs on the tub front, and door shroud, than you shouldn't have any problems.
Posted on Jul 18, 2008
My Neptune washer leaves an odor in my clothes
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!^^^
Jun 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have a Neptune washed since 2001 -- has an odor, b...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@^^
May 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Superstack water accumulation and odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!%5
Jan 27, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Smells like mold or mildew
Wash an empty load with bleach. This may wash out mold or mildew stuck in the water lines and pump. If it seems to help, do it again.
This is for internal issues.
If the problem is external, the machine may just need a good cleaning.
Jan 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
2002 Maytag Neptune front load washer has an odor like a burnt rubber odor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!@@
Nov 17, 2009 | Maytag MAH6500 Neptune Front Loading...
My Maytag Neptune has just started new odor
The rubber belt from the engine to the drum is loose: replace it, it's worn out.
Nov 16, 2009 | Televison & Video
Problems with mildew around the rubber and terrible odor to the laundry after washing. Also, hear water sloshing when turn the drum by hand.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Nepture washer Model MAH 5500 boot mildew
The new boot replacements are anti-microbial have a smoother surface and are designed to be more resistant to mold issues with proper care. Unfortunately, there are still a lot of the old boot replacements out there. The part number for the upgraded boot is 12002533..., This part number supercedes all prior part numbers for the Neptune boot assy...Hope this helps
Jul 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Mold and smell
This is a problem common to many front load washers. Besides being very important to wile the the rubber boot down thoroughly there are a couple of products that claim to get rid of the mold and smell. I, myself, have ***** tried these but you might want to give it a shot. One of them is called Purewasher and is offered on the site www.smellywasher.com. Some time ago Maytag came out with a Mildew/Odor kit that they may still provede. again, I don't know for sure how well it works but it too may be worth trying
Jan 27, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
606 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
