Question about Samsung HLP4663W 46" Rear Projection HDTV
Color replaced def color wheel. now have bad color. no service adjustments helps. heard there is a bulletin and/or modification because of updated cw. any info?
  • dar1 Jul 18, 2008
    thanks. i found the jumper and then did an indexing re-alignment. appreciate the directions.
  • schisesi Sep 27, 2008
    CHANGED COLOR WHEEL ON SAMSUNG WHERE IS THIS JUMPER
    Champion:
  • 217 Answers
There may be a jumper to remove on the DMD board, some of these models require it, it could be a factory setting, there may be 2 choices of color wheels in the factory mode, the way you get into the factory mode is with the Samsung remote that came with the tv, hit the MUTE button then 182 and then the power button, may take a coupls of tries before it works, good luck
Posted on Jul 18, 2008
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
Samsung hlr5078wx DLP tv. rumbling noise and shaky picture
This is a color wheel problem.
I would recommend to use professional help because you can make more damage to the optical engine. Not to mention index delay have to be re-adjusted in special service menu after repair is complete.
Regards.
Russ.
Jul 23, 2010 | Samsung HL-R5078W 50" HDTV
Bosch Washing Machine wis 24140 can it be affected by microwave as last washine machine we had also a Bosch needed a plate put in as the element used to over heat
In short, no. A correctly functional microwave oven should not affect any other appliances.
I can offer no comment regarding your last Bosch washing machine as you haven't given any specific details, but as with all brands there are sometimes models which are found to require in-service modifications and service bulletins and modification kits are then made available to engineers. I haven't ever heard of the modification which you mention on any Bosch washing machines though and it's not mentioned in my service bulletins folder.
Jun 14, 2010 | Washing Machines
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Loud buzzing noise has gotten louder and we know it to be the color wheel as the fan has been replaced. How can we replace the color wheel?
Hire the shop to replaced the colors wheel,because if u replaced,and adjust it wrong,ur power will sutdown.Well cause more problems than same some money.
Jan 15, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HRL6167WX/XAP rear projection TV and the TV went out one day when the color wheel exploded. What happened was that the color wheel exploded, then the reapir guy came and replaced that,...
yes , u need to remove this jumper , and the whine would go away , the bulletin is unique for each color wheel , the jumper is very small so just take u time to look for it , is located at the dmd board
May 07, 2009 | Samsung HLN5065W 50" Rear Projection...
Another color wheel goes bad
You cant the HM95 is a combined unit like some sharps, you have to replace the entire engine
Jun 10, 2008 | Toshiba 52HM95 52" HDTV Projection...
50v720 Color Issue / Reply w additional details
I'll check on your specific model, but this problem is usually caused by degradation of the LCD light engine. Hopefully we can work around it for the short term. I'll update this with the model specific info in a day or so (I'm traveling at the moment).
Dan
Apr 01, 2008 | Hitachi 50V720 Television
Samsung HLN617W
If it is it will be the first I've heard of one shattering... The CW spins at 7200 rpms and at that speed anything is possible. What color is the glass?? Clear and it's not the CW.. My bet is on the lamp. Does the lamp fire up?? You need to do a bit of investigating and let me know and I'll try and help..
Good Luck!
Bill
Dec 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
