Eq does not work - Audio Players & Recorders
  • 682 Answers
Confirm the following:-1-power cable in a good condition.
2-input cable is ok.
3-output cable is ok.
4-power switch is on.
5-volume level and other setting are in good level.
Posted on Jul 18, 2008
Yamaha rx v757 av receiver
tape out to line in on eq, line out from eq to tape in on receiver, use tape monitor switch to make eq work
Mar 14, 2014 | Audio Players & Recorders
I have a Fisher stereo.The amp is a ca871 the eq is a ca871 the casset deck is a crw870. How do I connect these components up.
The amp has tape rc out and pb. The eq has line in, line out, tape rec out, tape pb. The casset deck has line in,line out.
Ok, hook the amps RC OUT to the eq's LINE IN.
amps RC Pb to the eq's LINE OUT.
The tape's LINE OUT to the eqs TAPE PB
the tapes LINE IN to the EQs TAPE REC OUT.
on the eq, there should be a button to toggle between tape and source.
let me know if that works.
Jul 01, 2011 | Audio Players & Recorders
I think I have my cables run improperly/no eq when playing tuner
You could tell us how the tuner, cd and eq are connected for a start. I suspect a Tape Monitor or Source/Tape switch is involved, either in the EQ itself or on a receiver if you have one.
Then you could start isolating for bad connections and cables by swapping the (separate???) tuner into wherever the CD is connected.
Jul 16, 2010 | AudioSource EQ200 Home Equalizer
Telescope working principle
This is a reflector style telescope. It may also be on an equatorial mount. If it is on an EQ mount the mount must be polar aligned first in order to properly use the telescope. That's why we never recommend an EQ mount to a beginner.
However you can read my tips on EQ mounts on my profile page. AND-- read these:
http://www.texasastro.org/telescope.php
http://www.texasastro.org/mounts.php
http://www.astronomyboy.com/eq/
Jul 15, 2010 | Galileo (G118DX) Telescope
Looking to hook up an older model fisher EQ (EQ-961) to a newer Sony amplifier (STR-697).
Typically you would place an EQ or any processor2_bing.gif in a Tape Loop:
MD/Tape (or Video1) Rec/Out to EQ In; EQ Out to MD/Tape Play (or Video1) /In on the amp. Select MD/Tape (or Video1) on the receiver to place the EQ in-line with whatever source you're playing. Use it's ability to modify the sound sparingly.
Be advised, use of an external processor will only work for analog stereo sources and will likely DISable anything digital as soon as you activate the switch that puts it in the signal path.
Feb 23, 2010 | Audio Players & Recorders
Cant get equalizer to work with my receiver
This might work fish76, The EQ needs a in & out source to operate correctly? If you have audio device connected to an aux input disconnect that & connect the EQ to that audio device & then plug the EQ to the Sony receiver AUX input. The tape monitor is the most important source for hooking up an EQ device, so you are very limited on a total receiver or amp tonal connection source. The bottom line is you can only use the EQ if another audio source to plug into it & the EQ plugs to your pre-amp input on the back of your rec or amp
Feb 03, 2009 | Sony Audio Players & Recorders
I am trying to work 2 equilizers together in my stereo set
My big Q is - 'Why are you wanting to use two EQs in the first place, when one will suffice. But that is not for me to ponder over. :)
How are you trying to hookup the EQs? I have my eq connected between my preamp and amplifier. The other common method is to insert the eq in the tape loop between cassette and amplifier/preamp. Then select the tape loop to put the eq in the signal loop. You then connect your tape player through the tape monitor jacks on the back of the EQ and select this option in otder to play tapes.
If you have two tape inputs, then you can insert one eq into tape 1, and the other eq into tape 2 and choose accordingly. Bear in mind that you dont have to use the tape in order to use either EQ in your system. Just make sure you are using one EQ or the other. If you attempt to use both, then you run into potential signal 'corruption' (i.e. loss of datta or signal pumping, depending on the frequencies enhanced/attentuated).
Dec 18, 2008 | Audio Players & Recorders
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Jvc kd-g720, hook up eq
yea but you will only have control on the low side of the eq. your beter off using that eq for your mids and highs
Oct 02, 2008 | JVC KD-G720 CD Player
Connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
May 28, 2008 | Audio Players & Recorders
21 people viewed this question
 Grubhead
Grubhead
