Question about Garmin GPS
Route calculation error not enough memory available is the only reply I am getting from my Garmin 610 with Ireland,U.K. and European mapping. It will calculate Irish routes after large delay
  • 50 Answers
SOURCE: screen says memory full and it won't map a route! GRRRRRRR
Hi, Please do not shoot the messenger (me) but this is a known problem with Garmin GPS units. According to Garmin Tech Support, this only occurs on Garmin units with older firmware. (Personally, I am not convinced this is actually true. I no longer have my Garmin C550, which I personally liked the best out of all the GPS units I have owned or used. I will buy another Garmin, probably a Nuvi, when this silliness sorts itself out.) Anyway, you have two options, neither of them acceptable to most people, including me. 1)Perform a HARD RESET which will wipe out all data on your unit, including your favorite points, Bluetooth connections, and almanac data (satellite information). Your unit will then need at least 40 minutes, with a clear view of the sky, to update the almanac and reacquire its location. To HARD RESET, unplug your C550 from the charger and turn it off. With the C550 screen facing you, press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER. You need hold both constantly for at least 30 seconds. Follow the instructions on the screen. See if any of your personal information is still there. If there is none, then you might as well perform Step 2 below. 2)Download and Load New Firmware onto the C550. Upgrading firmware is relatively easy provided you have a computer. Visit Garmin's website ( Go to "Support" .. "Updates and Downloads" and then click "Unit Software." Download the software called WebUpdater. Run that and follow its directions. The new Firmware (Software that is loaded into internal memory that does not need power to remember the information) hopefully will fix the MEMORY FULL problem. Good Luck and please post back if the fixes helped or not. I really want the new firmware to work so I can buy another Garmin.
Posted on Oct 06, 2007
  • 113 Answers
SOURCE: garmin nuvi 200 route calculation problem
Sounds like a major software failure. . .
Hold a finger on the upper right corner of the screen while powering up the unit. This should do a master reset.
The go here to download an update.
Posted on Oct 26, 2007
SOURCE: Garmin nuvi 250 mapsource
Thanks for the help. I managed to resolve the problem by installing the program on an external SD memory card.
Posted on Jan 29, 2008
SOURCE: Nav Cam 6400
I've wiped the card and copied the back files off the cd back onto it and put the update back on.
Seems to be working fine now but you will loose all your settings and favourates.
Posted on Jun 25, 2008
SOURCE: route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Posted on Jul 21, 2008
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
European maps not on Garmin
call garminj. they will talk you through it
Oct 26, 2009 | Garmin Nuvi 610 GPS Receiver
I bought a sat navigation (unknown) brand from ebay few years came with route 66 map installed on sd i can upgrade the maps on it?
The GPS system sounds like it may be a Garmin brand and the mapset you're talking about sounds a lot like the "Mad Maps" for "Route 66". The Mad Map collection consists of specialized maps for particular use or interest. There are maps other than the Route 66 map in the collection available.
Depending on GPS model, you may be able to download new maps to the GPS or obtain new maps on memory cards from Garmin directly. The Route 66 map card may not be large enough to hold current US maps - new US maps require 1 to 2 GB of memory.
Contact Garmin Customer Support to determine which GPS model you have and which map products are available for it, below:
North America - Consumer Products (for all Garmin products except Apollo aircraft)
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
E-mail Product Support
Europe - Consumer Products (for all Garmin products except Apollo Databases)
Austria For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 43 (0) 3133 3181 0
Belgium For all Garmin products except Aviation.
Friday: 9:00 AM – 15:00 PM (GMT/UTC +2)
Phone: 00 32 2672 5254
Denmark For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM Central European Time (GMT/UTC +1)
Phone: 00 45 4810 5050
Finland For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 16:00 PM (GMT/UTC +3)
Phone: 00 358 19 311 001
France For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 33 1 5517 81 89
Germany For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 17:00 PM Central European Time (UTC/GMT +1)
Phone: 00 49 898 58364 880
Italy For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 13:00 PM / 14:00 PM – 17:30 PM (GMT/UTC +2)
Friday: 9:00 AM – 13:00 PM / 14:00 PM – 16:30 PM (GMT/UTC +2)
Phone: 00 39 02 3669 9699
Portugal For all Garmin products except Aviation.
Monday – Friday: 09:00 AM – 12:30 PM / 14:00 PM – 18:00 PM (GMT/UTC or GMT/UTC +1 depending on city)
Phone: 00 35 1214 447 460
Spain For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 13:30 p.m / 14:30 PM - 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 34 934 972 373
Sweden For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 00 46 7744 52020
United Kingdom For all of United Kingdom users and customers in unlisted countries in Europe, Africa and Middle East
Monday – Friday: 8:30 AM – 17:30 PM Western European Time (GMT/UTC)
Phone: 00 44 808 238 0000
Oct 07, 2009 | GPS
Have a Garmin nuvi 200 with North America maps. Am downloading a map of Ireland. Will this erase my existing maps of N. America?
It will depend on how much memory you have in your Garmin. If you have maps that you want to keep then I would download those first and then add in the Ireland maps. Or wait until you leave to add in Ireland. I believe the Garmin will tell you if there isn't enough room to add in Ireland.
Aug 17, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
USA Garmin nuvi 200. Can I download Ireland map?
You will have to buy a version of European maps. After you download them into your Garmin it will work just like in the US.
Here is a link I found for you. It looks like you need to buy all of Europe but there may be a way to just buy individual countries. Best wishes on your trip.
Wide and way cool, nüvi 200W shows you the way with detailed maps on a bright ... Garmin Garage" vehicles compatible (download car-shaped icons to your device ): yes ... nuvi 200W, Eastern Europe, 010-00656-25. nüvi 200W, Italy, Greece ...
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Garmin Nuvi 660 lost Europe maps
Eventually managed to speak to a man at Garmin who confirmed that it was not loading any European maps because it didn't have enough spare memory to load them all. He said that he would email me instructions for freeing up sufficient memory, the email never arrived but I decided to delet all the voice languages that were no use to me and all the other language 'help' files and tried again - it worked.
At no point did I get a 'insufficiant memory' warning, which would have been very helpful, nor is there any guidance for how much memory will be required when embarking on the update. Take note Garmin...
Feb 27, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 610
Oct 27, 2008 | Garmin Nuvi 610 GPS Receiver
I keep getting memory full message and route waypoints full on nuvi 610/660
The Navigator memory card will come with the a countrie's maps. Maybe you need to take the memory card into the computer and download more maps. Also try to erase the nt middle east location and start over.
Jul 08, 2008 | Garmin Nuvi 610 GPS Receiver
GPS Logo
228 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
