On your driver side, lower left side, down to where you would place your left feet, there is a handle that has a hood logo on it, pull this handle back, and your hood should be released, then go to your hood, toward the center of the hood, slide your hands under the hood and lift it up a little bit, (it won't open yet) then there is a release lever that needs to be pull, (be easier if you take a look) with your fingers, and once you pull on it, should release your hood, and then open the hood.
Locate the interior hood-release lever under the dashboard on the driver's side of the interior of the car.
Lift up and toward you on the hood release lever. The lever is connected to a cable that releases the hood. The hood will pop up about 1/2 inch when you pull the lever.
Move to the front of the car and locate the exterior hood-release lever under the front of the hood. It is located near the middle of the vehicle, just beyond where the front edge of the hood meets the body. Lift up on the inner lever.
Lift up on the edge of the hood while holding the inner lever in place. When the hood is up, find the hood prop and raise it, setting its tip in the hood-prop mount on the hood, to hold the hood up while you work in the engine bay.
