Question about Sharp EL-1197PIII Calculator
Loading paper I cannot figure out how to load paper in my calculator. It has been a long time since I used it. Don't know how to load roll of paper
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Follow the illustrated instructions on the first page of this manual.
Posted on Apr 05, 2013
PA8558
  • 28 Answers
SOURCE: Loading paper
A lot of times, the paper will not advance into the calculator without the paper being cut STRAIGHT ACROSS. Try cutting it straight across and then try to feed it in. The rollers should be able to grab the paper at that time.
If this helps, please rate me. Thanks, Patty
Posted on Jan 04, 2008
  • 168 Answers
SOURCE: Load new reel of paper
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Posted on Feb 10, 2008
SOURCE: loading paper
Look on the back of the calulater, you will see a little slot by where u plug in the cord. if you put the paper in there and push it in some and press feed it will pull it to where it needs to be. It is very easy to do. it took me a whille to figure out what everyone means but it really is easy,
Posted on Sep 24, 2008
  • 3 Answers
SOURCE: HOW TO LOAD THERMAL PAPER IN DR-T120 CALCULATOR
Simply place the paper between the plastic posts. Put top portion down; feed paper up slightly - put smaller front plate back in place and press feed button.
Posted on Dec 29, 2008
SOURCE: How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Posted on Jan 23, 2009
Canon p1-dhv Lost manual and can't figure how to load paper roll!
http://www.usa.canon.com/app/pdf/calculator/P1-HDV_G_USA_HWB.pdf
This is for the P1-DHV-G but the paper loading process should be the same.
Feb 20, 2011 | Canon P1-DHV Calculator
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2¼-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
How do you load paper into a canon p23-dh v
For loading paper into canon p23-dh v is to cut a piece of index card to the length of 3 inches and to the width of the paper you want to load. Tape evenly to the end of the paper roll and put into the ****, pushing gently in and at the same time pressing the 'Feed" button. It will immediately feed since it is firmer than the Poat-it paper.
Apr 26, 2010 | Canon P23-DH Calculator
CANT FIGURE OUT HOW TO LOAD THE PAPER ROLL
How to use the subtotal function on Casio HR-100TM
Jan 18, 2010 | Casio HR-100TEPlus Calculator
How do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
Nov 06, 2009 | Canon P23-DHV Calculator
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
I cant' get new paper installed on desktop calculator
There is a small **** right where the paper roll gets installed - it looks like the seam between the top and the bottom of the calculator. The paper feeds from the roll directly into this - maer sure you have a very clean edge to start with - then turn on the print function and push a button until it starts to feed through. Be patient with it but it will work.
Dec 20, 2008 | Canon BP120 DH Calculator
Hope this helps.
Have a good day.
M =)
Feb 10, 2008 | Victor 1230-2 Calculator
Sharp EL-1197PIII Calculator Logo
168 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
