Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Do not turn this television on! Any electronic that smokes is NOT GOOD! The smoke and accompanying smell is from plastic and solder that is being melted by a short on one of the TVs logic boards. Call a local TV repair man this is not an issue you could fix yourself and will most likely be better off buying a new television. Stay away from off brands like these, spend the few extra bucks on a name brand like Sony, Toshiba, LG, or Samsung and you won't encounter these types of issues.
hi the most common fault on this tv is what you describe .i fixed mine by replacing the capacitor (1uf 630vdc) at location c19 on the power board .. cost for this component less than 90p
