SOURCE: error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
SOURCE: Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
SOURCE: oven lights will not turn off, Maytag gas double oven range Prec. touch 750
Hello bohlke75,
Welcome
You said, After cooking in the upper oven today, my wife noticed that both oven
lights were on. I tried to turn them off but the oven light button just
beeps when activated. I individually tried the plunger switches on
both doors but that did not work either. You also unplugged the stove with
the hope it would cancel the lights but they came right back on when i
plugged it back in. You assume it is something in the touch pad since
both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Huuum
Please remember to leave a rating!
SOURCE: maytag performa model per4311acw
The oven's element may be defective. Take a look at the heating element and look to see if there are any unusual 'marks' on the element.
It is a simple fix.
Unplug the stove, unscrew the screws holding the element to the back of the stove, gently pull the element a few inches towards you, pop off the connectors, take the element out and take with you to the store. It is a good idea to take the model nukber with yoy when you go to the store.
To replace, just reverse the steps above.
