Question about Microsoft Xbox 360 Halo 3 Special Edition Console
How do you open a xbox 360 Halo reach edition xbox? Thanks in advance
    Problem Solver:
  • 12 Answers
I will provide a step by step process on how to open up or disassemble the xbox 360, the steps takes You all the way to the lens. Pleas get these instruments(Bath towel, Flat-edged screwdriver,
Posted on Feb 08, 2011
  • 597 Answers
I will provide a step by step process on how to open up or disassemble the xbox 360, the steps takes You all the way to the lens. Pleas get these instruments(Bath towel, Flat-edged screwdriver, #15 Torx screwdriver, Phillips jeweler's screwdriver, Tweezers, White glove, Compressed air) then follow the steps below:
  1. Unplug the Xbox 360's power cord and remove any cables, game controllers and USB flash drives connected to it. Place a bath towel on a table. Place the console vertically on the towel with the faceplate facing up.
  2. Grip the left top side of the faceplate and the bottom right side. Pull the left side of the faceplate to the left and the bottom right side up to remove it from the console.
  3. Rotate the console so that the vent-like holes are on either side. Insert the tip of a flat-edged screwdriver into each of the holes and lift up to release the inner clips.
  4. Place the console face down on the towel. Raise the shelf on the bottom to reveal the screws beneath it. Remove these screws with the Torx screwdriver. Return the console to an upright, horizontal position on the towel. Grip the sides of the console and pull the outer case off.
  5. Remove the screws at the back panel with the Torx screwdriver. Pull the back panel off the console. Pull the plastic inserts on either side of the console off. Remove the screws from the metal shield on the top of the console with the Torx screwdriver. Pull the metal shield off.
  6. Locate the DVD drive that is on the console. The DVD drive is a rectangular metal box with a warning sticker on the top. Remove the screws from around the drive with a Phillips jeweler's screwdriver. Lift the drive up and pull the two cables out of its back.
  7. Place the DVD drive on the towel face down. Remove the screws from the sides of the drive with the Phillips jeweler's screwdriver. Slide the case off the drive.
  8. Turn the drive over. Locate the lens assembly at the center of the drive. Remove the screws from the clip placed on the drive that is next to the spindle at the center of the lens assembly with the Phillips jeweler's screwdriver.
  9. Remove the clip. Grip the lens that is under the clip with a tweezers. Remove the lens from the lens assembly and dispose of it in the trash.
  10. Put on a white glove. Pick up an edge of the replacement lens with the hand that is wearing the white glove. Place the lens in the depression that was formerly occupied by the original lens. Rotate the lens to seat it in the depression. Place the clip back on and reattach the screws. Blow off the lens and laser assembly with a burst of compressed air.
  11. Place the back panel on, reattach the screws and return the plastic inserts to their original positions on the console. Place the outer case back on. Turn the console over and reattach the screws to the bottom. Return the console to its original location, reattach the cables, game controllers and USB flash drives to their original positions. Plug the power cord back into a wall outlet.
Hope this helped. Thank You for using FixYa!!!
Posted on Jan 26, 2011
SOURCE:
Halo reach game unrecognized
it may be your xbox
if you have a white arcade its your xbox
it eventually get worse so save the ones u can on to your hard drive
Oct 08, 2011 | Microsoft Halo Reach for Xbox 360
I need offline xbox 360 mods for halo reach
google or youtube them
they are usually made by people and uploaded so virus scan it first or your computer or xbox may be dead
have fun and remember there are scans on xbox live so check when the scans occur and dont use hacks within the 3 days before or you can get xbox banned :)
Oct 01, 2011 | Microsoft Halo Reach for Xbox 360
X box 360 halo reach freezes in middle of game.
take the hard drive on the top off, blow in it, make sure that there isn't dust build up and then put it back on, check your disk also and make sure it isn't scratched, also ensure your harddrive isn't filled up, ensure there is memory left so your system isn't overloaded.
Mar 23, 2011 | Microsoft Xbox 360 Halo 3 Special Edition...
Where on the box is the hlo pc key?
The Halo PC key refers to your serial key you have for installing your copy of Halo C.E. for the PC. It isn't located on the Halo Reach box or in any sort of pamphlet included with Reach since it is for an entirely different game.
Jan 24, 2011 | Microsoft Halo Reach for Xbox 360
I got a 2 day xbox 360 xbox live card from halo reach limited edition and i did it but i am sill silver.
You have to log off your profile and then log back in for the changes to take effect.
Sep 16, 2010 | Microsoft Xbox 360 Console
Wont turn on its likes its out of batteries but i cant open it to get into it xbox 360 halo 3 limited edition wireless mic
Hi, you don't need to open it. There must be a charge cable in the box, just plug it to the headset then to Xbox and let it recharge for few hours. Regards Peter
Aug 05, 2010 | Microsoft Limited Edition Halo 3 Wireless...
Xbox 360
i counter that with jfci paeusfrk]Q@# VPYZSAEF kfhdj gsd g.f4dg5a41d 1g +z+ 4sf 4cf 45A F98 451 PINGUS
Jun 25, 2010 | Microsoft Xbox 360 Arcade
Microsoft Xbox 360 Halo 3 Special Edition Console Logo
1,647 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
