Question about Whirlpool Duet GHW9150P Front Load Washer
F28 error Yesterday; July 18th I went to put a load of whites in the washer, maybe like a medium load. Well it started like normal and so I went on doing other house chores. I went back to my washer because I had it on the whitest whites cycle and for 84 minutes it was done fast. I noticed on the display where the remaining time would have been an F28 error message. I just really find this very unconvinent because I am moving today and need to wash my clothes. The set that I bought is just barely a year old and the washer is already broken? I mean I know this is not the first time this problem has ever happened; well to me it is. I would really like to know if there is a recall on the Whirlpool Duet GHW9150P Front Loader Washer; if not there needs to be. Up until now I loved my set now I don't know if the repair guy comes if the problem will be fixed or not. What does the F28 error mean anyway? I tried calling whirlpool to see if they could help me and they just said to select the drain/spin cycle and the door will unlock; well it didn't. Nothing seems to work and its really confusing me. Do you suggest anything else or am I just screwed at this point?
  • 3 more comments
  • Anonymous Aug 14, 2008
    I had the F28 problem from my intital use of my new washer. Not only that, I have to start a cycle about 10 times then force a rinse/spin before the stupid piece of junk will actually run a cycle for a normal duration. It, until that point will just squirt some water in and stop while never progressing to the wash phase as seen on the little diaplay while the cycle timer continues to count down. I'm very unimpressed with this washer. I guess that's why I got it for free with my log home kit.
  • Anonymous Feb 10, 2009
    what the **** F28 mean?
  • draftwoman1 Mar 29, 2009
    I have the same problem, and was told it is an internal electrical problem.
    I now have to call a service tech to fix it.
  • draftwoman1 May 11, 2010
    Thanks, I will try this and report back.
  • amer3597
    amer3597 Nov 27, 2012
    I have a Whirlpool duet .and i had the F28 problem I follow the troubleshooting in service manual ,(found in the front botton of the machine)i got MOTOR CONTROL UNIT Bad ,i took out and found burned with dark spot.the MCU is on front left botton side
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Posted on Jul 24, 2008
  • brenda May 21, 2012
    Hi I am having the same problem but I was also cleaned my filter to. You said the "bottom toe panel" is that the front bottom that I have to take off to clean the filter? Could my problem be that I didn't put that on right?
I have an F28 error what is wrong
As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES F28 MEAN
Error codes were F28 (serial communications error) If you have removed the control panel cover there is a small switch that must be taped down, otherwise when you put the cover back on it may allow that switch to remain up and cause this error. If you have never removed the cover and are getting this error it could be a bad control panel.
Mar 22, 2011 | Kenmore Front Load Washer
F28 error / water starts to fill then quits in 15 sec's
F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
It was putting out a error code of f28 I changed the main board on the inside of the washer no it wont run the last spin cycle but it will do every thing else was there anything else I was supposed to do...
F28 error means the CCU(central control unit) lost communication the the MCU(Motor control Unit) for an HE2 washer.
I would look inside the lower front panel and get the tech sheet and run a diagnostic test per the instructions... See what comes up. Review troubleshooting for the F28 make sure you did not miss anything.
I hope this helps
Mar 20, 2010 | Kenmore HE2 Plus Front Load Washer
ERROR CODE F28
Unplug the machine at the mains. Remove the detergent tray. Reach all the way back with your hand in the slot where the detergent tray normally fits and feel for a lever. When you find it pull it forward. Then replace the detergent tray. Plug the machine back on and the error code will have reset and the machine will be useable again.
Oct 05, 2009 | Whirlpool Washing Machines
What does f28 error mean
Your camera does not support the aperture range, maybe.
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F28 ERROR
I have a Kenmore Elite that has done the same thing, I had to press power and then start (to start a new cycle) then the stop/cancel button and this unlocked my door. Power and then cancel/stop just turned off the power again and did not unlock the door. I hope this works for you.
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
5E Washer - Won't Fill / F28 Error
check if hoses are reverse when installed
May 12, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
7,124 people viewed this question
Dan Webster
Dan Webster
prem mathew
