Samsung HLR4266 no Picture
Hi All,
My TV is about 2 years old. One day, the picture decided to not come on. I get the blinking "lamp" light I instantly thought the bulb was bad, but upon opening the back, I find the bulb is as bright as anything. So I thought maybe the ballast. But I am told the ballast turns the bulb on...so that can't be it.
I assume at this point it is the color wheel but can someone confirm. Anyway to tap it back into working. I do get a whirling noise occasionally at startup but still no picture
  • bcvickers Feb 24, 2009
    I have this exact same problem. Press the power button and the lamp light blinks, the bulb turns on, the fan(s) turn on, I cannot confirm that the color wheel is spinning, the whole screen looks back lit, and I never get the startup "melody". Eventually the lamp light quit's blinking and it goes back to standby mode.
ctf1800
  • 4402 Answers
SOURCE: Tv Shuts off occasionally 1min upon power up shows red lamp light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 11, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
  • 4234 Answers
SOURCE: Issues with replacing Ballast
The flash code indicates that the lamp cover is not installed correctly. There are safety switches built into the housing that require the cover be installed correctly for the set to work. If the cover is actually in place correctly, there may be a broken switch. Check for this and update this if you can not resolve the problem.
Dan
Posted on May 08, 2008
I have Samsung DLP HL-R4266W bought in Aug.2005. Now it has no picture, no sound. After replacing new lamp, the same problem remains. I was also told it could be the problem of ballast. Please tell me where you can buy the ballast? Where is the ballast located in DLP TV? Thank you.
Posted on Jul 16, 2008
  • 1694 Answers
SOURCE: Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Posted on Jan 24, 2009
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
I have the Samsung HLN5065W DLP television, and if I press the power button the TV will act like it is going to power on but won't. The lamp light will blink but I never get a picture. It seems like it...
It seems tv needs lamp replacement, please check lamp in tv and if lamp has not been replaced in last 2-3 years or lamp is broken, replace it to solve tv problem.
Thanks.
Jan 22, 2011 | Samsung HLN5065W 50" Rear Projection...
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
My Samsung Dlp model hlt5075s was working great with great picture for last 2 years. This afternoon I went to cut it on and it the three lights on the bottom right started blinking(standby, time, and...
The projection lamp life is over.2 years has not been replace projection lamp,tv on daily watches like 4 or 5 hours a day?u need to replaced the projection lamp.
Sep 12, 2010 | Samsung HLT-5075S Television
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Televison & Video Logo
328 people viewed this question
Top Televison & Video Experts
