Texas Instruments TI-86 Calculator Logo
Posted on Jan 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using a TI-86 calculator and whenever I try to do even the simplest problems (1+1) I get weird answers (10b) or "error"
Anonymous
Level 2:
Novelist:
  • Expert 100 Answers
  • Posted on Jan 26, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
100
Questions
0
Helped
100380
Points
237
Hi mandajoytoll,
Your in binary mode. All you can enter is 1 or an 0 in that mode or, your going to get an error. That is what the b at the end of the number is telling you, Binary! You probably want to change to Dec mode. Press [2nd] [MODE] and arrow down about 5 time. You'll probably notice Bin is highlighted. Select Dec by pressing [ENTER] to go to decimal mode calculations. Then press [EXIT] or, [2nd] [QUIT]. If you have any questions just post a comment and, I'll respond quickly.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442704
Points
622693
Your calculator is in binary mode, where only the digits 0 and 1 are allowed. To switch to decimal, press MODE to bring up the mode screen, use the arrow keys to highlight "Dec" on the sixth line, and press ENTER. Press 2nd [QUIT] to exit the mode screen.
I have a TI-86, whenever i input - it shows Ans- and then it show that is an error. how can i fix it.
The - key is for subtraction, an operation that needs two numbers. If you press - as the first key on a line, the calculator assumes you want to subtract something from the previous answer, Ans.
If you want to enter a negative number, use the (-) key on the bottom row of the keyboard, just to the left of the Enter key.
TI-86 error code 08 number base
If you are doing base N calculations
You may have entered a wrong digit (binary: digits are 0 and 1; octal : digits are 0,1,2,3,4,5,6, and 7) OR
You are trying to do calculations that are not valid in Base N.
Turned on ti 86 and have a black screen. I have replaced all of the batteries and still is black.
Whenever the screen is full and a line with calculation result comes up at the bottom of the screen, the screen all of a sudden shows things in a weird way and can't be read. By press "2nd+mode"(=quit), or try reset button (a small hole which a pin can only be used to press it to RESET. Gud Luck
1helpful
What does error #13 dimension mean on my TI-86 calculator, please.
Three possibilities:
1) You entered an argument with an inappropriate dimension.
2) You entered a matrix or vector dimension < 1 or > 255 or a noninteger.
3) You attempted to invert a matrix that is not a square matrix.
If you need further help, please specify the exact problem you're trying to solve.
1helpful
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to [email protected].
1helpful
2answers
HOW DO I USE TI-86 FOR FRACTIONS
surround the fraction in parenthases.
1/64
would read (1/64)
Thanks for using FixYa - a 4THUMBS rating is appreciated for answering your FREE question.
1helpful
TI 86 error 17 INVALID
You're trying to reference a variable or use a function where it is invalid. If you're still struggling with this, post a little more detail as to exactly what you're trying to plot.
7helpful
TI-86 Calculator Problem
Most likely you're trying to graph a function while you have the stat plot turned on. Turn off the stat plot and try it again.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
