Question about Wave Industries OLY-OL3000 Globe Phone
Cannot access menu
When press the "Select" button, all I get is the words "CID LIST", hit the button a second time and get "No CID". It will never go to the Menu as the instructions say it should.
    Problem Solver:
  • 6 Answers
Use the up and down button to scroll through the menu choices. Once in a menu choice, use the left and right buttons to scroll sideways. A little confusing, but once you get the hang of it, it becomes second nature.
FYI - "CID LIST" is the first menu option, so you are in the menu at that time. As soon as you get to "CID LIST" hit the up or down button to go to the other choices. If this makes no sense, post back and I will try to help. :)
Posted on Aug 11, 2008
My Uniden Dect handset has stopped working. No dialtone. Also message on handset reads:'New CID:50'
CID(caller identification) your phone logs incoming calls in it's memory. The #30 signifies that there are 30 CID(phone #'s) logged in the memory of phone from callers. The phone saves the information for the last 50 received calls to the CID list. The NEW icon marks any calls received since the last time you checked the list. You can delete these one by one or all by pressing ID (CID# will come up) then press menu/select button I believe 3x and repeat until all unwanted CID's are deleted. page 9-10 of the Dect 6.0 manual below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button. https://www.101phones.com/content/pdf/un...
So your problem isn't related to that message. Disconnect your unit from the wall plug. Remove the handset battery, count to 10 and put it back. Plug the base unit in and try again. You need to check the line jack with a standard phone to make sure the line is good.
https://www.101phones.com/content/pdf/uniden/D1760.pdf
Dec 06, 2017 | Uniden Lands Phones
We have just purchased a Uniden Xdect 8355 series telephone. When the phone rings we get a message telling us who the call is from, how do we get rid of it?
Do you want to delete entries from the Caller ID list? This records the numbers of the last 50 incoming calls. You can't delete the entire list at once. However, you can delete one entry at a time. Press CID on one handset or base with the entire system in standby (no active calls). The CID button is to the right of the Menu/Select button. Press the Up/Down arrows (above and below Menu/Select) to select one call. Press Menu/Select to get the details of that call. If you don't see list with Delete Entry, Add to PB, and Add Call Block, press Menu/Select again. Select the Delete Entry line and press Menu/Select. Select Yes and then Menu/Select again if prompted to confirm the deletion.
When you are done, press End/Clear to exit the menu system. You'll find these directions on page 30 (page 31 of the pdf) of the manual. Uniden has the manual here: https://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_8355_OM.pdf .
I hope this helps.
May 18, 2017 | Uniden Lands Phones
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
New phone DECT1480. How do I delete the new cid numbers
To select a number, highlight the number and press Menu/select. The phone gives you the following 3 options:
1) Delete Entry Erase the number from the list.
2) Store Into Pb Add the number to the phonebook. The handset prompts you to edit the name and number.
3) Delete All (CID list only) Erase all numbers from the list.
Friends phone:
1) Check batteries
2) Check base unit has good mains connection ! faulty mains extension
Oct 18, 2017 | Uniden Lands Phones
I purchased a Uniden model D1688 and I don't know how to put favorites into the phonebook.
Entries can be added from the base or the handset. The CID button is on the right of the control ring; the phonebook is on the left of that ring.
If you want to add a number from the Caller ID list to the phone book, press CID and use the up/down arrows to navigate to the call that you want to add. Then press Menu/Select. Select the line Store into Pb and press Menu/Select. You will be at the Edit Name Screen for the phonebook.
To enter a new item from scratch, press the Phonebook button. Then press Menu/Select and select the Create New submenu. Press Menu/Select and enter the name of the contact using the alphabet on the key pad. (For C, press 2 three times.) Press Menu/Select and enter the phone number as it is dialed (including a 1 if needed). If you need to add a pause in the number, press Redial/Pause. However, the entire number must be less than 20 digits (including the pause). Press Menu/Select again. If you enter the number from the handset, you will be prompted to select a ringtone to always use when you get a call from that number. Press Menu/Select again. Then press End (on the handset) or Play/Stop (on the base) to exit the menu system.
Uniden has the manuals available at their site, either from the product page or the support page. All DECT phone manuals are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are listed in numerical and alphabetical order. The direct link to the D1688 manual in English is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1688-2om.pdf .
I hope this helps.
Aug 30, 2011 | Cell Phones
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
Samsung LE32R7 in DTV mode stays on BBC1
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
How do you turn ringer on and off on a uniden exi8560 cordless 5.8ghz
hello. To turn the ringer off on that phone you need to get into the menu. The way you get into the menu is press and hold the menu/cid button for 2 seconds. Then press the arrow down button until you highlight the ringer volume. once the ringer volume is highlighted, press the select/channel button. that will rotate you through the 3 available volume levels. High, low and off. as you are pressing the select/channel button the handset sounds a sample of the volume level. when you hear the volume level you want simply press end and that will store your volume to the off position. to turn it back on, just repeat the above steps but select the proper volume level you want and then hit end. I hope this helps.. Don;t forget to rate me. thanks !
Sep 07, 2009 | Uniden EXI8560 5.8 GHz 1-Line Cordless...
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Just bought CD445 cordless phone with answer phone. The event light on the handset is flashing all the time. Is this normal. What do I have to do to stop it. Many thanks
The message indicator is the phone alerting you that you have missed calls. Press the CID button (the up arrow) then menu. You are now in the call list. Scroll through it (using up & down arrows) making sure to view all calls with the word NEW next to them. Alternatively, you can press menu while in the call list and then choose delete all this will erase the entire list.
The light also blinks to indicate voice mail. Many phone providers offer this service for free and you should contact them to ask if you have it / how to check it.
Jan 28, 2008 | Vtech mi6896 Trio Cordless Phone
Wave Industries OLY-OL3000 Globe Phone Logo
143 people viewed this question
Top Wave Industries Lands Phones Experts
Are you a Wave Industries Lands Phone Expert? Answer questions, earn points and help others
