Refrigerators Logo
Posted on Jan 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a side by side kenmore, #53522300 and neither side is cooling. All fans, motors, and air flow ducts seem to be working properly. Also I have taken off the back cover of the freezer and the coils were warm> What will cause this?
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Jan 30, 2011
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10835125
Points
101584
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Why is it blowing warm on and off on the driver side and blowing cool on the passenger side?
Here's is a little background and a couple of thoughts. Turning to the background, first. The heater/air conditioner system in your 02 uses the same set of ducts located in the instrument panel. In turn, those ducts are linked to what can be considered miniature version of the cooling system in the engine compartment (yes, this is a greatly simplified version). The whole system, in fact, is run off the main heater/ac system, however, it has a separate series of controls so that it can function properly.
When you dial a temperature, a signal is sent to the heater/cooling system telling the system to open a series of baffles, directing a flow of heated or cooled anti-freeze/coolant to the proper "radiator" behind the face of the instrument panel. In turn, the fan system activates a series of doors behind the instrument panel so that the flow of air is directed through the "radiator" and into the passenger compartment. This is essentially the heater/cooling system work.
Now, you say that the driver's side is hot, while the passenger side is cool. What has happened is that the flow of heated coolant that is supposed to heat the passenger side of the duct system is blocked. Since there is no heat to warm the air that is flowing past the fins of the "radiator," the flowing air remains cool to cold, depending on the weather and ambient temperature. The result is that one side of the car remains cool. And, since the other side of the "radiator" is normal and the air is heated, it is warmed.
That is the most likely explanation for this.
Another possibility is that the baffles themselves are stuck and the coolant that is supposed to be directed to the passenger side is not being directed their.
Either way, your technician has some work ahead.
Refrigerator is running, but it does not seem to be cooling. Freezer side seems to be ok. Have cleaned coils.
Not detailed description of your Refrigerator Problem?
1) Frost free system (Heater, Timer, Drain heater) properly not functioning.
2) Evaporative Fan not working (Check Air flow satisfied or not)
3) Compressor properly not working.
4) Thermostat (1,2,3 ) problem. (Rotate high and check)
My heater fan only works on the 3 and 4 speeds
Common problem here, The heater motor resistor has to be checked, (located in air-flow ) between motor housing and ducting to heater assy ! Usually 4/5 wired componant located for cooling purposes in air duct governing the heater motor voltage ! Good Luck
2helpful
2answers
Inside refrigerator strip between the freezer and refrigerator
The condenser fan motor at the back near the compressor is either dirty or not running at proper speeds. Clean the coils for air flow over compressor and if the fan is not running replace the fan.
Refrigerator will not cool It stays at 50 degrees Freezer works fine
Look for a blocked duct or a bad fan motor in the freezer. The cooling is done in the freezer and the cold air is circulated via ducts and a fan. No air flow= No cooling in frig. Long shot could be a light not going off when door is closed, seen that a few times in 20 years...
Eric
1helpful
I HOPE I AM USING THIS PROPERLY......MY ? IS IN MY
The indoor blower motor is sometimes a 3 speed motor.The heat usually works on low or medium speed.But the a/c is usually on high speed,this gives greater air flow across the evaporator coil to give you better cooling,also better air flow at ducts.These speeds are usually wired through a relay in the inside unit (air handler).They can be changed.If you go to thermostat and put the fan switch to "on" the blower should operate on "high" speed.With the fan switch set to "auto"the operation will determine the fan speed.Hope this helps. Gregg
2answers
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
The refrigerator side of my kenmore refrigerator does not cool
Make sure the evaporator fan is operating. Since the fresh food side is cooled by the air flow from the freezer side. Check for blockage of the air duct from the freezer to the fresh food side. Set the temp control half way. Over adjusting this setting can cause problems with cooling. If I can help you any farther, let me know.
2helpful
2answers
Refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
7helpful
My microwave is sweating
No. This is usually a sign of poor venting or air flow. It's possible that the coling fan is not circulating the air properly due to a problem with it or maybe the air vents are blocked. Also, there needs to be a couple of inches around a countertop model on all sides - especially the back - to ensure air flow. Look for buildup on the back vent grille. You can listen for the fan to be running and feel the air flow while it's running. If it's weak or not there, it needs inspection / service. A lack of air flow can cause the magnetron to overheat and be damaged. If this is a built-in model also check your air filter, air duct work and outdoor vent flap. Write back if you still have trouble.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
