Question about Konica Minolta DiMAGE Z10 Digital Camera
Camara can't be turned on normally
I have to take out batteries and put them back a few time to turn on my camara in display or viewfinder mode. At first i doubt my battery's problem and replaced with new batteries, it was the same.
  • gina8630 Dec 04, 2008
    I am having the same problem it kept saying low battery no matter how many times I have changed them. Then one day i go to turn it on and it wouldnt turn on i checked the batteries and then i took out the memory card. As soon as i took it out it started to work. I put it in and it stopped.
Posted on Aug 10, 2008
How can I stop displaying the photo information on the view finder?
In the viewfinder? The viewfinder will always display things like the f/stop and the shutter speed while you're preparing to take a picture. This cannot be turned off.
If you mean on the monitor on the back when reviewing your photos, simply press up/down on the multiselector to cycle through the different views of your photos.
Jan 10, 2011 | Nikon D40x Digital Camera
My camara will not turn off a the button, I have
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | GE A730 Digital Camera
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
Can not turn the camara on
Digital cameras drain lots of power for a short period. The best batteries for digital camera are rechargable types. It is either you are using normal alkaline batteries which are easily drained or your rechrgable batteries are not properly charged. Try solving either of these two problems.
Sep 01, 2009 | Nikon COOLPIX L100 Digital Camera
Camara on blackberry phone does not work
Try turning off the phone and then removing the battery for a few minutes. Replace the battery and then then let the phone reboot, it should work fine after it reboots.
May 31, 2009 | AT&T Blackberry Curve 8300 Smartphone
Unresponsive buttons because of engaged zoom
the reason why the lens zooms out is because the zoom switch is faulty and might need replacing.The way to tell this is when you switch it on in camera mode you will see the zoom bar displays on the lcd and stays there.
Jun 01, 2008 | Panasonic DMC-FX07 Digital Camera
Camara doesn't take pictures
when a please turn on and off again appears there is normally a fault with or in the lens. I dont like to suggest that the camera must be opened by anyone that is not qualified to do the repairs because these cameras have components in that could be damaged and will only make the problem worse.
Jan 01, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
CAMARA turns off when i press to take a photo
I have the same camera... and it was doing the same thing AFTER i changed my old batteries, because they were getting low. It was only after i put in the NEW batteries that i had this problem... I tried putting the old batteries back in and sure enough it worked again, so it probably all just depends on the brand of the battery you use.
Oct 09, 2007 | Fuji FinePix A500 Digital Camera
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Sep 19, 2006 | Samsung Digimax A7 Digital Camera
Konica Minolta DiMAGE Z10 Digital Camera Logo
146 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
