Question about HP Pavilion ze2000 Notebook
Screen problem inquiry
How do i connect an external monitor to my laptop. is it possible to use a monitor of my pc
  • 45 Answers
Yes You can use the Monitor From your PC,
Just need to find the port where you would connect the Monitor on a Notebook
Give me the Model number of you Notebook Ill Give you the Details...
Posted on Jul 22, 2008
6930 black screen
Try connecting it to an external monitor if possible.
You can use the VGA connector on your laptop to connect it to the Monitor.
restart the laptop and see if it comes up on the external monitor.
If it does show on the external monitor, It's probably the laptop screen going bad. and they ain't cheap. here's a link to a screen on Amazon, just to give you an idea...
Amazon com HP EliteBook 6930p Laptop Screen 14 1 LCD CCFL WXGA 1280x800...
If it still doesn't show, Hold down the function key and press the CRT/LCD button (Usually F8) to see if you can cycle between the external and the laptop monitor..
Hope this helps
Apr 16, 2014 | HP EliteBook 6930p Notebook PC
Laptop turns on but is at a black screen
Connect an external monitor to your laptop, power up the external monitor first then boot up your laptop. The video information will automatically divert to the external monitor.
If you see Windows on the external monitor then the fault could be a faulty CCFL lamp or inverter that supplies high voltage to the CCFL lamp.
Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 09, 2012 | Toshiba Satellite L655-S5096 Notebook
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
HOW TO REMOVE SCREEN FROM DELL VOSTRO 1000 AND CONNECT TO A MONITOR
if laptop is still running with a broken LCD screen , it id possible to use an external monitor, if laptop totally died or broken, not possible to use with external monitor.
Mar 26, 2012 | Dell Computers & Internet
I have a R51 that when it boots up it only shows a white to gray shade screen
If it is at all possible, connect an external monitor to the computer. All laptops should have a port for an external monitor. If the external monitor works then you screen is most likely bad and needs to be replaced. If the external monitor does not work then your motherboard is probably bad.
May 06, 2011 | IBM ThinkPad R51 Notebook
Screen don't work (black) screen.
You can use the VGA connector on your laptop connect it to the Monitor.
If it does, or doesn't, Hold down the function key and press the CRT/LCD button (Usually F8) to see if you can cycle between the external and the laptop monitor..
Hope this helps
Dec 19, 2010 | Compaq Presario CQ50-215NR Notebook
Broken screen, external monitor via VGA won't
Press "Fn+F7" once, wait a few seconds, and press it again, to "cycle" through all the possibilities (LCD-only, VGA-only, both).
Try the monitor with some other computer (desktop or laptop) to see if the monitor works at all.
Restart your computer -- does the initial "splash" screen (showing CPU speed and RAM-test) show? Does the "Windows" screen (with the crawling worm) show on the external monitor?
Nov 16, 2009 | Lenovo 3000 N500 Notebook
My laptop screen is half white half color whats wrong and how do i fix it?
From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I hope this helps answer your ?'s. Good Luck ^_^
Sep 13, 2009 | HP Compaq Presario V6000T Notebook
Hp dv5000 half screen gets stuck and blurry
It is recommended that you replace your screen.
Mar 17, 2009 | HP Pavilion dv5000t Notebook
Gateway laptop 450 rog
be sure to circle through possible screen.
use FN key + a key with a screen symbol on your keyboard (or check your doc) to switch from main screen to external monitor and back.
sometime some techies use external monitor for pc final test and forgot to restore configuration to laptop screen.
At restart XP is expecting the last used monitor and nothing shows on laptop screen.
try also connecting any external monitor to vga plug.
let me know if is fixing
Jan 04, 2009 | Computers & Internet
HP Pavilion ze2000 Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
