Up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
SOURCE: Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: low battery in Uniden cordless phone.
Unless you have one of the water proof phones, hold the handset with the keypad facing your palm, and the top facing your body. Press very firmly at the endention on the battery cover pushing it in a little and down at the same time. Sometimes they are pretty tight but it should come off with a little effort. If it is a waterproof phone, there are four small screws at the corners of the battery cover that will need to come out before the cover will come off, be very carefull as the screw heads are fairly easy to strip and if that happens it is almost impossible to put it back together and still have it waterproof.
SOURCE: I have a uniden cordless phone model tru9480-3
With the phone in standby, press and hold [dnd] on the base. You will hear a confirmation tone and the [dnd] LED will go out.
Testimonial: "Thanks IT Worked"
